code P0171
Old Nov 6, 2013 | 09:46 PM
Rastan's Avatar
Rastan
Default code P0171
Hey, guys I have been getting this code P0171 system too lean (bank 1) on my 96 LT-4. The car seems to run great, and I'm trying to find what this is in the FSM. But I'm not having any luck so far. Can someone chime in and give me clue. Any help would be great. Thanks in advance.
Old Nov 6, 2013 | 11:02 PM
Klyde's Avatar
Klyde
Several things can cause a lean problem. An air leak after the air flow sensor, a bad injector, and weak fuel pressure are a few. Bad fuel pressure would/should show up on both banks. It is rare for an air leak to only show on one side but could happen. The most likely would be an injector or two on one bank being bad. The other item that affects one side is a bad O2 sensor. Since the car runs fine I would narrow it down to the O2 sensor on bank 1 side. The rear pair are only for smog checking and are not used in any way by the computer so it would be the front one that's bad. If you have not done it yet I would replace the injectors and O2 sensors. They should be done every 50k miles. It should clean things up fault wise but you will be happy with the improvement in gas mileage and performance even if it doesn't. Another thing that should be looked at/replaced is the PCV valve and hoses. These are maintenance items and like plugs and wires should be serviced on a regular basis.
Old Nov 7, 2013 | 12:07 AM
don hall's Avatar
don hall
In addition to Klyde's informative post, read post #2 in the following
link...... may help (?):
http://forums.corvetteforum.com/c5-t...171-p0174.html
Old Nov 7, 2013 | 12:11 AM
RUU's Avatar
RUU
First Google search result for "P0171"
Old Nov 7, 2013 | 06:45 AM
grandspt's Avatar
grandspt
I think I remember one of my friends having this code on his fairly new back then LT4 Vette. They traced it to a bad diverter valve.
But obviously don't just change parts. Make sure it is bad before replacing it. I think the valve ruptured internally and allowed excess air into the exhaust stream (if I remember correctly it was 17 years ago).
Good luck let us know what you find.
Old Nov 7, 2013 | 09:20 AM
bassackwards's Avatar
bassackwards
Mine was caused by a bad o2 sensor. New sensors and it ran really good
Old Nov 8, 2013 | 10:56 PM
Rastan's Avatar
Rastan
Wow! Thanks for all the possible causes. I will look into the cheapest first. May daily driver needs help also. I will post the cure when I find it. I think it may be the MAF because I was getting a MAF malfunction before this new code
Old Nov 17, 2013 | 12:18 AM
Rastan's Avatar
Rastan
I had the maf sensor cleaned and the lean code seems to be gone. However the maf malfunction is back. I clear the code and it is back as soon as I crank the car. The first few time I cranked the car it sort of stumbled upon cranking. Normally it will turn twice and start immediately, but this was only for the first few times. I'm going to look into a new sensor.
Old Nov 17, 2013 | 12:25 AM
okinawa86vette's Avatar
okinawa86vette
One of my lt4s had the same code and it was the intake gasket. Other areas for air to get in and affect one side are the injector o rings at the intake.
To determine if its a vac leak or sensor, you really need a scan tool to look at your O2 values and the corresponding bank's injector pulse/ block learn values.
Otherwise, you're sort of throwing parts at it hoping you hit the right one.
Old Nov 27, 2013 | 06:29 PM
Rastan's Avatar
Rastan
I unplugged the maf sensor and cleaned it out. So far I've driven about 400 miles and no check engine light. I still have my fingers crossed but, as soon as I fix my daily driver I can get the intake, and valve cover gaskets replaced, as well as looking for other leaks.
Thank you all for the detailed advice, I wrote it all down for future reference.
To code P0171
