Confirmed; Another One Bites the Dust
Old Nov 8, 2013 | 02:54 PM
Crepitus's Avatar
Crepitus
Good stuff Will!
Old Nov 8, 2013 | 03:15 PM
tunedport85inject's Avatar
tunedport85inject
If i remember Chuck Quaile ,while he was building his engine, made a full lifter valley polishing...mirror like,is this a good feature for best oiling?
Old Nov 8, 2013 | 09:47 PM
rklessdriver's Avatar
rklessdriver
Not really. Back in the 80s we polished every inch of internal casting on blocks... mainly to remove possible stress risers. We used alot of factory GM blocks back then and HP was approaching 650 and they were just stressed way too much for an endurance application..... When I was a kid this was my first big job in dads shop.... diegrinder a carbide burr and about 6hrs....
Whats important for oiling is opening up the 4 drain back ports in the valley and the 4 drain back ports in the cyl heads.
Will
Old Nov 8, 2013 | 10:04 PM
rklessdriver
Originally Posted by l98tpi
Thanks for the advice. I do intend on better oil pump, higher grade bearings, and Canton RR Pan even though this car is mainly street. I only used it a few times due to my other car being down.
And I am going to mention the forementioned grinding to open up the passage. One would think since the LTx motors were designed to produce power in he higher Ron's they would have considered cavatation and oil starvation.
Thanks for the condolences on the second blown motor.
And, just saying and may just be coincidence; my L98 lasted longer than my LT4 before failure.
Buy what you want but I would recomend the Champ or Moroso RR pan over the Canton... the door/gate system is better. Price is in the same ball park.
As far as what GM designed into the LTX oiling system over everything else... same simple stuff they have used in "high perf" sbc for many yrs.... 3/4" oil pump pick up tube and a main cap mounted "Z28" windage tray.
Will
Old Nov 8, 2013 | 11:03 PM
l98tpi's Avatar
l98tpi
Max G’s
I will check out the Champ and Moroso. Mainly went with Canton because a lot of other guys I know run the Canton. I may try a different one for this car. Even though it is not a dedicated track car it will see some action from time to time.
Old Nov 9, 2013 | 10:28 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Different RPM range, is my first thought...
Old Nov 9, 2013 | 10:48 AM
1991Z07's Avatar
1991Z07
While I agree with everything Will said about oiling systems, I disagree about his stance on an AccuSump.
A properly engineered and massaged oiling system SHOULD be fine...but I view the AccuSump as cheap insurance. After spending north of $5k TWICE in a year on engine work...a $300 AccuSump is well worth it.
I took a cue from one of our longtime members in how to use it for startups...he has a manual valve on a cable. He opens it as he cranks it over and floods the bearings with oil to extend the life of the engine. The electronic solenoid makes it much easier...but it is certainly another item that COULD fail.
Of course...finding a place to put an AccuSump in a C4 engine bay is another matter entirely!
I wish there was room for a dry-sump system...but finding a place to put the sump in a C4 is close to impossible on the L98 block. Everything is packaged pretty tightly...
Old Nov 9, 2013 | 10:01 PM
l98tpi's Avatar
l98tpi
Max G’s
I have been told that one location to use is the area where the spare tire is normally mounted. But, I question if that is too far away and couldn't get the oil back to the sump quick enough to maintain oiling to the bearings? I do think it is a good upgrade and may install one myself.
Old Nov 9, 2013 | 10:05 PM
l98tpi's Avatar
l98tpi
Max G’s
Definitely could be.
Old Nov 9, 2013 | 10:42 PM
1991Z07's Avatar
1991Z07
Depending on if you use a 2 or 3 qt system...
You can mount it to the cross-beam in front of the engine (where the accumulator is mounted). You have to fab some bracketry...and it has to come out when doing anything around the front of the motor, but it's doable.
Old Nov 12, 2013 | 06:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Is anyone adding an extra qt of oil for their track events?
Old Nov 12, 2013 | 06:58 PM
Rob31's Avatar
Rob31
I am . Also a stock pump , not a high volume . Im thinking some 5K PLUS rpm with a high volume pump is why some guys are having problems . My motor never sees 5K
All that oil gets pumped to the top half .
Just did a trackday ,Autoban Full course on slicks 160 k On the clock .
with no issues . extra half qt.
Old Nov 12, 2013 | 09:39 PM
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Copy all that. Thanks. That all agrees with my thinking on the matter as well.
Old Nov 12, 2013 | 10:46 PM
  #34
l98tpi's Avatar
l98tpi
Max G’s
I will take a look at that location and see what kind of room I have. My car sits pretty low also, so want to make sure have enough clearance.
Old Nov 12, 2013 | 11:00 PM
  #35
l98tpi's Avatar
l98tpi
Max G’s
I have never added extra oil above the full mark but if you do make sure you secure your PCV valve and the ventilation valve on passenger side. I have had the PCV valve come out in a turn and oil go all over and caused me to spin out. When you hit oil, there is no control, you just have to wait for the ride to end. Does give you a bit of a rush as long as you don't hit anything.
Old Nov 12, 2013 | 11:41 PM
  #36
cv67's Avatar
cv67
St. Jude Donor '05
I would think that extra qt would just get whipped up into a foam (aerated) starving the pump anyway?!
Old Nov 13, 2013 | 06:40 PM
  #37
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'd have thought so too based on what I learned in auto school. But my C6 came with instructions in the owners manual to add an extra qt for track days, auto x, etc. I know the C4 has a different engine but I think I recall hearing the same procedure for it too. I think. Anyway, I've followed that practice for my track days too, with no issues.
Old Nov 13, 2013 | 11:39 PM
  #38
1991Z07's Avatar
1991Z07
Best place is either on top of the cross member, or in front of it.
If you put it in front...you'll have to find another location for the accumulator.
