1994 Corvette LT1 Code help
Old Nov 7, 2013 | 10:19 PM
VirajPatel21's Avatar
VirajPatel21
Default 1994 Corvette LT1 Code help
I have a 1994 corvette with a Lt1
I pulled these codes from the lcd screen using the paperclip method.
I'm also getting crappy MPG around 11-12 city and 18/19 on highway
I'm suspecting o2 sensors are bad.
Can you identify what they are?
Modular 4
-H13
-H63
-H64
Old Nov 7, 2013 | 10:35 PM
WVZR-1's Avatar
WVZR-1
Modular 4
-H13
-H63
-H64
Bottom of this link:
http://tech.corvettecentral.com/2011...trouble-codes/
Old Nov 7, 2013 | 11:00 PM
VirajPatel21
Originally Posted by WVZR-1
DTC 13 - Bank 1Left Front) Heated Oxygen} Oxygen Sensor (H02S) #1 Circuit (Open Circuit)
DTC 63 - Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Open Circuit)
DTC 64 - Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Lean Exhaust Indicated)
Does this mean both of my O2 sensors are bad??
Old Nov 8, 2013 | 01:44 AM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/1585377116-post2.html
Replacing the O2 's may not solve it , you have to do the diagnostics from the FSM to identify what is actually causing the code on the O2 sensor(s) circuit.
To 1994 Corvette LT1 Code help
