Sound Deadening and Jute
Old Nov 9, 2013 | 04:07 PM
Klyde's Avatar
Klyde
Default Sound Deadening and Jute
I've tried to sift through all the post to get a definitive answer but am still confused. The original jute backing was for heat and sound deadening. Once you install some kind of modern sound deadening material you should no longer need the jute. Those of you with experience doing this, did you also reinstall the jute or just install the carpet over the new sound deadening material? Adding the jute could cause fitment problems because most newer material is quite thick. I have a roll of Rattle Trap and I'm thinking of doing this over Winter/Spring hibernation. I just as soon not use the jute but if it most be done I will.
Old Nov 9, 2013 | 04:48 PM
blue94's Avatar
blue94
I would check with the manufacture but, I used Second Skin Audio's kit of Damplifier Pro and Luxury Liner Pro and dropped the juke backing.
Old Nov 9, 2013 | 05:00 PM
383vett's Avatar
383vett
Dynamat and other foil looking insulators are lighter than jute if that is a concern.
Old Nov 9, 2013 | 05:22 PM
Klyde's Avatar
Klyde
My concern is the mat and also jute being too thick.
Old Nov 9, 2013 | 06:59 PM
Joe C's Avatar
Joe C
I used second skin audio damplifier pro with the factory jute when I installed new carpet in my 85. as I recall, 80 square feet and a lot of work, but everything went in without issues.
Old Nov 9, 2013 | 09:18 PM
DUB's Avatar
DUB
If you apply an adhesive back foil product. And then a foam pad like "Dynapad". I (personally/professionally) do not use the jute because it is overkill and is not going to do anything to greatly improve what was just installed....and will hold moisture( if wet) and also odors...and will break down over time...in the used area of the carpet. If my customer does not want to pay for the Dynapad. ...then I do apply the jute....because at least installing "something" is better than nothing....and it duplicates what was factory installed. The jute used in days past has been surpassed by technology in acoustical/heat barrier products of today. Some manufacturers still use it..but most REALLY NICE cars do not use it from the factory any more. It is the way it is. Much like ..when have you seen an 8-track tape for sale in a store?
By the way...SURPERB JOB JoeC!!!! I KNOW what time you had in that job.
DUB
Old Nov 9, 2013 | 11:10 PM
Klyde's Avatar
Klyde
I agree. Great job Joe C. I hope to do half the job you did. So you put the jute over top of the foil backed matting? I'm afraid that it would be too thick in some places. Do you have to glue the jute to get it to stay in place? Wow that looks great!
Old Nov 9, 2013 | 11:45 PM
smooth1990's Avatar
smooth1990
Great Job!
How much of a difference did that make?
Old Nov 10, 2013 | 12:42 AM
Cliff Harris's Avatar
Cliff Harris
I used HushMat, which looks the same as Joe C's stuff. It's very thin (about 1/8" thick), so I put the jute on top of it. It didn't cause any problems that I remember.
I did cut away the HushMat around the studs that the seat rails mount on so the rails were more solidly and directly connected to the body.
Old Nov 10, 2013 | 03:06 AM
Joe C's Avatar
Joe C
thanks. i put the factory jute over the foil backed mat without glue. as I recall, it wasn't overly thick and didn't cause any fitment issues.
Originally Posted by smooth1990
Great Job!
it made a noticeable difference in the sound quality, but it wasn't lexus quite. the sound coming through the doors was more noticeable - I didn't use the foil backed stuff in the doors, but I did use the late-model C4, foam, factory door liners. if I had to do it again, I would have gutted the doors and installed the foil mat to the inner door skins. overall, the 85 felt more solid, so there was a noticeable difference. the down side is the added weight - probably about 40 pounds
DUB
thanks! that job seemed like it took forever. I only worked a couple hours per day and only several days a week. like anything, things snowballed - I had to repair broken mounting tabs on the dash skeleton among other things. i'm kind of ****, so every piece was cut, trimmed, and fitted during installation. all the seams were covered with a foil back furnace tape. I even insulated the interior surfaces of the rear storage cavities. overall, my interior redo took several months.
Old Nov 10, 2013 | 02:48 PM
armysnipe's Avatar
armysnipe
On my 93 coupe I used fat mat rattletrap for my installation. I reused the original jute in the back because it was already conformed to the back of the car. At the same time I installed new mass backed carpet over it and didn't have issues. In the picture the black is boom mat spray. In the front I used new padding that came with the carpet kit. On the bulkhead behind the seats I only reused the foam type pad that was there. On my doors I just replaced the vapor barrier with the foam type and are very happy with the sound quality.
Some tips: clean the SMC before applying the fat mat, don't try to use the biggest piece possible as smaller pieces are easier to apply, press the edges of the mat with a roller and it will join together, degrease edges with non chlorinated carb cleaner when overlapping the mat, tap on areas to see where matting is necessary, use spray on hard to reach areas
Good luck!
Old Nov 11, 2013 | 03:01 AM
Cliff Harris
I put in the later model foam sound deadeners about 10 years ago. I didn't even think of doing the doors until I saw a picture a few weeks ago with the foil stuff inside the doors. I have a few pieces left over so that was added to the project list.
I bought a HushMat kit for the front of a full sized car. I couldn't believe how heavy the box was.
Old Nov 13, 2013 | 02:25 PM
69mako's Avatar
69mako
Wow! There are some real considerations here on what insulation matt to use…or not use in the case of factory jute.
I’m researching these issues and products for a carpet install story I’m working on. Feel free to drop me a PM if you have any additional “tech tips” or comments you’d like to share.
Thanks!
To Sound Deadening and Jute
