So I'm breaking down the top of my L98 to swap out the head gaskets. After breaking several T-40 Torx bits (Sears saved me with a T45 hardened bit) I removed the intake and noticed that the drivers side rear port had a metal piece from the manifold gasket...when I swap out a new gasket should I remove that foil to allow the coolant to flow through the back of the intake journals? Also who makes a good intake manifold bolt kit?
noticed that the drivers side rear port had a metal piece from the manifold gasket... should I remove that foil to allow the coolant to flow ?
That is factory fitted restrictor to control the coolant flow
Do yourself a favor and buy Allen head cap screws , more common and generally cheaper than the Torx style , less prone to stripping the head out
From any engineering supply or nut and bolt shop
I would suggest getting the intake gaskets with the rear restrictors when you replace the intake manifold.. I asked this same question a few years ago on here about which intake gaskets to get for my 89 and almost everyone said to go with the stock gaskets with the restrictors...There also the ones listed in the Factory Service Manual....WW
Gentlemen, they are not restrictors, because there's no flow across the back of the tpi intake. I think they were more of a plug.
To the OP: using Felpro blue coated gaskets with a thin layer of silicon at the water jacket ports only will reduce the electrolysis GM created with the stock steel gasket. Do not use silicon at intake ports.
Sorry but my 89 has coolant in that rear crossover, there's also a small coolant line going from that crossover to a tee in the heater hose on my car....I remember hearing something about the restrictors were to keep the rear of the head from running colder then the front of the head..Those gaskets have a small hole in them to restrict flow...WW
Gentlemen, they are not restrictors, because there's no flow across the back of the tpi intake. I think they were more of a plug..
As the man above said.
There is a bleed port (brass plug by the dist in pic ) from the rear coolant crossover that the GM engineers installed because apparently
they thought there might be a problem with air or steam pockets on the new alum heads
The aftermarket didn't agree so most AM intakes have no rear coolant port at all.
You are correct. The 14081005 from the early cast iron does not (which I have), but the aluminum head does. My apologies for egregious error. It should be note that the Later Camaro L98 does not have this passage either. Only the one with the rear EGR port. in any event, the restrictors will come in the Felpro kit. I just threw mine away, because they weren'y needed.
No problem Mr ******......It looks like the restrictors were only used on the 305 and 350 cars from 86-91, but they were used on SB chevy trucks for a longer period....From what vetteoz says it looks like they really aren't needed at all since most of the aftermarket companys don't use them and they don't have any problems.....WW
No problem Mr ******......It looks like the restrictors were only used on the 305 and 350 cars from 86-91, but they were used on SB chevy trucks for a longer period.. I agree with vetteoz on the after market intakes because my 383 with the Edelbrock intake didn't have coolant in the rear crossover, it was blocked off , only the stock intakes used them...WW
My research showed only Corvette aluminum heads had the crossover. No cast iron headed car did whether 305, or 350. I knew mine didn't have it, so I went on flea bay and looked.
Honestly, I don't see the purpose. Too me it would seem to be a stagnant flow by design?
Your correct, because they even indicate on the Summit racing site that the intake gaskets with the restrictors are for use only on 1986 aluminum heads and up to 1991, not on the steel heads........WW
I will only add this for the OP. I would avoid using a steel piece between two aluminum items if it were me. I do like the idea of a bleed off as Vettoz mentioned to avoid any air pockets. Too me, adding electrolysis to a coolant system when it can be avoided is nuts. I think GM screwed the pooch on this one unless you do have a way to bleed this off.
I know I'm not the only one to pull off a GM intake with steel gaskets and have to have it welded and milled?
My '86 with cast iron heads does have the crossover passage in the rear of the intake manifold. I left the restrictors out. It's been about 10 years and I haven't seen any problems.
I also have a so-called "steam tube" that connects to the place previously shown (post #7) with the brass bleeder that goes to the heater core tubes.
interesting thread since i'm getting ready to rip the intake off my 90 to repair a rear china wall oil leak along with a bunch of other stuff - injectors, plugs/wires/cap & rotor, etc. I bought the exact same fel-pro kit from summit -
