D36 swap
Old Nov 10, 2013 | 01:35 PM
oilyfishhead's Avatar
oilyfishhead
Default D36 swap
'94 auto coupe.
I just picked up a D36 with a 3.07 gear to replace the 2.59. The book says pull the whole thing bat wing and all. It also says remove the exhaust pipes. Removing 20 year old exhaust pipes should be fun.
Are there any short cuts that y'all know?
Old Nov 10, 2013 | 01:40 PM
c4cruiser's Avatar
c4cruiser
There is one flange on the resonator with bolts, the other is a slip-fit. It might be easier to just unbolt the entire system at the exhaust manifolds. Then all you have to deal with are the hangers. Don't forget to unhook the wires to the O2 sensors.
Old Nov 10, 2013 | 02:03 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The exhaust system on the LT1 engines is a one piece cat-back. There are no shortcuts, you have to remove the whole cat back. Start with the emergency brake cable.
It has to come out anyway, you must support the C-Beam before your remove the differential/batwing.
Old Nov 10, 2013 | 02:14 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I left the wing on and just exchanged the pumpkin saves some work. You need to pull the exhaust from cats back like Petes pic and support the trans before you pull the c beam loose.
To D36 swap
