Weird problem , vid inside
Old Nov 15, 2013 | 10:47 AM
Mohammed_z's Avatar
Mohammed_z
Default Weird problem , vid inside
Why the door lock is acting crazy !!! It does this often. and it stops when I lock the doors when doors closed.
it's like the lock wants to open !!
click image below to start the video
http://s236.photobucket.com/user/evi...a18f3.mp4.html
Old Nov 15, 2013 | 01:55 PM
WW7's Avatar
WW7
There's a part in the door that I believe is called an "actuator" that opens and closes the lock.. If this part goes bad or has an internal short it can cause the lock to do what yours is doing..I would suggest taking the door panel off and seeing if this is whats happening..It's attached to the end of the rod that moves the locking mechanism .. It could posible be the switch that locks and unlocks the door also, Im not positive on this but it wouldn't hurt to check it out.........WW
Here's what an actuator looks like for your car....
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Old Nov 15, 2013 | 04:43 PM
Mohammed_z's Avatar
Mohammed_z
Thanks for the help , I will check for shorts
Old Nov 16, 2013 | 01:06 AM
rhinoevans's Avatar
rhinoevans
Mohammed_z
I own A 1994 Vette also, but it is in Las Vegas.
However, I am currently in Riyadh, Saudi Arabia. Been here for 1 1/2 years, but will leave back to the states in late Dec. I am in the NE part of town, near intersection on North and East Ring Road. Would like to see your vette before I leave if possible. I also have both FSM with me if you need to look up any thing.
Old Nov 16, 2013 | 01:19 AM
Mohammed_z's Avatar
Mohammed_z
Originally Posted by rhinoevans
Mohammed_z
Cool , sent you a PM.
To Weird problem , vid inside
