Help me!! Help me!! PLEASE!!!!
Old Nov 20, 2013 | 04:16 AM
Cliff Harris's Avatar
Cliff Harris
If the VSS signal is not getting to the ECM it will set error code 24. The SES light will come on after driving about a mile.
If the EGR system is not working correctly you will get error code 32. That one is more subtle and requires cruising at constant speed for about 5 minutes.
I recommend a minimum idle adjustment (haven't seen that mentioned in this thread) -- it cured my stalling problem:
http://forums.corvetteforum.com/1570563689-post1.html
Old Nov 20, 2013 | 05:28 AM
vetone86's Avatar
vetone86
Originally Posted by MrWillys
Which is a typical symptom of the ecm not seeing a vss signal, but you've discarded my advice to check to see if the ecm is seeing a signal and chosen drama.
no drama !! how do i check to see if the ecm is seeing a signal ?
Old Nov 20, 2013 | 05:45 AM
vetone86's Avatar
vetone86
i get no codes . will see about mia . thanks clif
Old Nov 20, 2013 | 07:34 AM
fc_soldier's Avatar
fc_soldier
For the sake of a quick test, Id test my coil. Maybe there is a 'heat soak' issue with the coil. Has your car died just after startup (within 5-10) or is more during prolonged use? I've also experianced fuel issues where at low pressure the fuel filter would clog but as on pedal itll be fine.
Old Nov 20, 2013 | 12:13 PM
desertmike1's Avatar
desertmike1
You may have posted and I didn't see this, what is your Idle normally? and does it drop slightly right before dying..
Old Nov 20, 2013 | 12:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Try cliffs link then find someone with a scanner in your regional section that can nail the problem for you
Old Nov 20, 2013 | 12:45 PM
vetone86's Avatar
vetone86
the idle is at 600 and no it does not drop
Old Nov 20, 2013 | 12:50 PM
vetone86's Avatar
vetone86
will do it today !!! thanks
Old Nov 20, 2013 | 02:42 PM
desertmike1
You might be a tad slow on Idle speed..
http://forums.corvetteforum.com/c4-g...dle-speed.html
Old Nov 20, 2013 | 03:02 PM
MrWillys's Avatar
MrWillys
Idle speed is called for in the programming, and the ecm is constantly trying to adjust for said programmed idle speed. Only a mis-adjusted throttleblade, or a device not reporting properly can change what is called for. A fully warmed automatic car in gear is close to 600, and a manual is 700. Open the throttleblade too far, and it will rise as it leans the mixture with too much air, and of course the opposite.
I generally don't approve of the minimum idle air procedure, because after it is done, 15 minutes later it can change. I prefer small changes will observing IAC counts, and tune to counts of 20 to 80 with 40 to 60 being best. The TPS will have to be adjusted on mass air cars after setting throttleblade.
Of course only an owner will have time, and desire to get it right using this method. A shop will use the procedure, and owner is stuck with result.
Old Nov 20, 2013 | 05:27 PM
vetone86's Avatar
vetone86
I followed instructions to set minimum idle adjustment. When I got to the part of starting the car, it went to 1500 RPM. Being the coward that I am, I was afraid to mess with it because there was such a difference. When I shut the car off and reconnected the IAC, and restarted the car, it went to 700 RPM in park, 600 in drive.
Did set the voltage on TPS. It was at .36 and I put it at .54. It idled very smoothly and ran for quite a long time with NO stalling. Will not know for sure until I get out and drive it.
Thanks for y'all's patience and the very clear directions.
Old Nov 20, 2013 | 09:02 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I agree completely with this method of setting the idle but I have always thought the counts should be down around 20, not as high as you state. Would you explain?
Old Nov 21, 2013 | 05:46 AM
  #33
Cliff Harris
I have seen people recommend 20. In my personal opinion that is too low. It doesn't leave much room for the ECM to reduce the air coming in. After it gets down to zero it can't go any lower.
I prefer around 50 steps at idle myself.
The ECM has a tolerance on the idle. If it gets within 50 RPM (75 RPM in certain conditions) of the target RPM it stops adjusting.
One thing I have never seen (but would like to) is the relationship between IAC steps and RPM. How many steps does it take to change the RPM by 100, for example?
Old Nov 23, 2013 | 03:44 AM
  #34
Midnight 85
Good to know, thanks.
Old Nov 24, 2013 | 09:43 PM
  #35
Euthymicone's Avatar
Euthymicone
Veteran: Coast Guard
This reply may prompt snickers and even guffaws. Oh well, ain't the first time. I had this happen several years ago with an old VW Beetle. I had put in a new engine and rebuilt practically every inch of the car. Then the engine started conking out. Took it to mechanics more times than I can count and just when we thought we had the problem solved, it would conk out again. New fuel pump, filter, fuel lines, on and on----I was getting ready to push the car off a cliff. Finally, a mechanic decided to pull the fuel tank. Sure enough, he found a leaf that had somehow gotten into the tank. Probably when I was pumping gas on an autumn day, who knows. The engine would run fine until the fuel level got a little low and then the leaf would clog up the works. That was it. The old thing ran fine after that. Probably a silly notion, but it was the first thing I thought of when I read your post. Good luck---I feel your pain.
Old Nov 24, 2013 | 11:14 PM
  #36
vetone86's Avatar
vetone86
Thanks, I followed the instructions that Cliff Harris posted and it seems to have taken care of the problem. Thanks you guys!!
Old Nov 25, 2013 | 05:49 AM
  #37
HlhnEast's Avatar
HlhnEast
******, he didnt discard, just said it was beyond his skill set. Explain further maybe that will help him. What do you use to tell if ECM sees the VSS?
My experience is electronics malfunctions throw codes but fuel issues do not.
To Help me!! Help me!! PLEASE!!!!
Old Nov 25, 2013 | 08:22 AM
  #38
vetone86's Avatar
vetone86
I haven't had a chance to drive it since following Cliff Harris' instructions. I have left it idling in the garage and it has not stalled. Put fuel pressure gauge on and when I turn the ignition to on position, it goes to 40 pounds of pressure, then drops to 20 pounds instantly. Hard to start, but once it starts it goes to 39 pounds of pressure. Once I turn the engine off, it goes down to 20 pounds of pressure and bleeds off in a matter of a minute or so, I assume I have an internal leak somewhere. I think it is injectors.
Old Nov 25, 2013 | 06:37 PM
  #39
floridamale's Avatar
floridamale
The fast leak down could be injectors, check ball in fule pump, cold start injector, or FPR
you need to test each to see what is leaking.
Old Nov 25, 2013 | 10:21 PM
  #40
Midnight 85
Try the search for the procedures on how to find out exactly what it is that is leaking pressure. I can't remember now what they were.
