Help me!! Help me!! PLEASE!!!!
Old Nov 19, 2013 | 12:46 PM
vetone86's Avatar
vetone86
Default Help me!! Help me!! PLEASE!!!!
I've searched to the best of my ability to find the information I need, but can't find it. I need help. I have an 86 automatic pretty much stock. Intermittent stalling at idle. Can be at red light, stop sign, in the garage. Starts right back up. Have owned the car since 2001. It started doing this about 4 years ago. Had new motor put in about 2 years ago and had no trouble until this summer. Problem came back. Idles fine. No codes. Have put in new fuel pump; fuel pressure is fine. New fuel filter and a jillion other parts. Everything under the hood is new. This car was the love of my life, as I love Corvettes, but I have gotten to hate this car. Have had it to mechanic after mechanic to no avail. I am not a mechanic. I can do simple repairs. Thanks Guys.
Old Nov 19, 2013 | 01:21 PM
ch@0s's Avatar
ch@0s
Is your TB and IAC clean? does it idle rough?
Old Nov 19, 2013 | 01:25 PM
don hall's Avatar
don hall
[QUOTE=vetone86].....No codes...... /QUOTE]
No codes? Does the 'serv eng' light illuminate during initial key-on cycle? Did you try downloading codes?
Old Nov 19, 2013 | 01:29 PM
jgalfo's Avatar
jgalfo
I have an '86 and I vote for the IAC it cured mine.
John
Old Nov 19, 2013 | 01:31 PM
desertmike1's Avatar
desertmike1
Are you running the same Throttle body on both motor's?
Old Nov 19, 2013 | 03:21 PM
vetone86's Avatar
vetone86
Brand new TB and no it does not idle rough.
Old Nov 19, 2013 | 03:23 PM
vetone86's Avatar
vetone86
[QUOTE=seabright;1585468545]
The serv eng light does come on during initial key-on. I have a code reader. No codes.
Old Nov 19, 2013 | 03:24 PM
vetone86's Avatar
vetone86
No. I have a brand new one. It ran perfectly for two years.
Old Nov 19, 2013 | 05:35 PM
vetone86's Avatar
vetone86
John
Can I purchase one from NAPA or should I go OEM? Thanks
Old Nov 19, 2013 | 06:05 PM
MrWillys's Avatar
MrWillys
Does the speedometer work? Can you scan it while driving and see if the ecm is seeing speed?
Old Nov 19, 2013 | 06:12 PM
vetone86's Avatar
vetone86
speedometer work
Old Nov 19, 2013 | 06:14 PM
MrWillys's Avatar
MrWillys
speedometer work
And does the ecm see this too?
vrone44's Avatar
vrone44
I'll just throw this out there. Check EGR system functionality.
Old Nov 19, 2013 | 06:48 PM
vetone86's Avatar
vetone86
over my head
Old Nov 19, 2013 | 06:51 PM
vetone86's Avatar
vetone86
Would I get codes? Sorry, but I'm not the sharpest knife in the drawer. That's why I have spent a small fortune on this car.
Old Nov 19, 2013 | 07:20 PM
floridamale's Avatar
floridamale
You should get a code if the EGR is not working right. I would check the Throttle Position Sensor to see if it's reading right after you come back to idle
Old Nov 19, 2013 | 07:50 PM
vrone44's Avatar
vrone44
Concerning the EGR system; I do not have a manual for your year and am not familiar with the particular technology. EGR appears to be controlled (actuated) by the ECM but if the valve allowing exhaust gases into the intake sticks on occasion it could cause a stall. They do get carbon deposits with time. Don't know if yours is new or original. It's easy to forget about it.
To Help me!! Help me!! PLEASE!!!!
Old Nov 19, 2013 | 09:47 PM
Kevova's Avatar
Kevova
does it stall at a stop or lifting off throttle coming to a stop? In garage does it start stall or stall shifting in to gear? anything at all done to car prior to this problem occurring?
Old Nov 19, 2013 | 10:09 PM
vetone86's Avatar
vetone86
Both. But when letting off of gas, it doesn't stall until RPMs are all the way down to idle. In garage it stalls just sitting there idling. But you never know when it's going to stall. It does not do it all the time. It doesn't spit or sputter, it just stops like someone turning a switch off or on and starts right back up.
Thanks!
Old Nov 19, 2013 | 10:24 PM
MrWillys's Avatar
MrWillys
Thanks!
Which is a typical symptom of the ecm not seeing a vss signal, but you've discarded my advice to check to see if the ecm is seeing a signal and chosen drama.
