1985 Bog when revving in open loop
Old Nov 20, 2013 | 07:10 PM
DanielRicany's Avatar
DanielRicany
Default 1985 Bog when revving in open loop
Hey guys, I have a 1985 corvette with quite a few mods, but when it was stock it had this problem too. The car will bog down when you rev it while it is cold in open loop. When you drive it during open loop it is very annoying because the car bogs during acceleration and you have to give it more gas to go.
Any ideas as to why this is happening? I guess let's think of some items that are active during open loop! Thanks for any help!
Old Nov 20, 2013 | 08:18 PM
383vett's Avatar
383vett
If you have a wideband or a scanner, you can tell if you are running too rich or lean. You could try getting an adjustable fuel pressure regulator and increasing the fuel pressure to see if that helps. It sounds like you are running lean. A tune might put you in the ballpark.
Old Nov 20, 2013 | 08:46 PM
DanielRicany
I do have a wide band sensor, AFPR, and a tune. The AFR readings are between 13:1 and 16:1, same as when in closed loop. The tune is not perfect yet, but none the less, it doesn't do it in closed loop.
Old Nov 20, 2013 | 09:25 PM
383vett's Avatar
383vett
When the car bogs, what is the afr?
Old Nov 20, 2013 | 09:32 PM
DanielRicany
Good idea! The car is at my father's shop right now so I will check tomorrow, and I'm assuming probably a lean reading. I have a video too of it.
https://db.tt/nxslbxmx
It may be kind of hard to tell in this video, but it does not respond right away.
Old Nov 20, 2013 | 10:37 PM
hooked073's Avatar
hooked073
So hard to tell anything by what you posted. But is there an aftermarket cam? seems idle is low and also I would check base timing
Old Nov 20, 2013 | 11:08 PM
DanielRicany
Yes there is an aftermarket cam. Flat tappet version of zz409 from tpis.
And really? No one else has ever commented on the idle rpm and I always thought it was fine. It used to idle at 900 - 1000 RPMs because the previous owner messed with the throttle adjustment screw. After I drew the screw all the way back it idled like garbage until I reset the tps.
Also, my timing is set at 12 degrees BTDC. Checked many many times.
The tune is also set for 12 degrees. My tuner says he doesn't see anything in the data logs that would cause that. And it can't be something I did with the mods because it was like that when it was stock.
Old Nov 21, 2013 | 07:45 AM
bjankuski's Avatar
bjankuski
You need to lool at your WB when it bogs, it is either lean or rich, I suppect lean. Your tuner needs to add more acceleration fuel (assuming it is lean) to eliminate the bog. (I am assuming you do not have a mechanical problem like low fuel pressure or failed throttle position sensor)
Old Nov 21, 2013 | 08:49 AM
DanielRicany
I will ask him, but shouldn't it be something not in the tune since it happened when it was completely stock too?
Old Nov 21, 2013 | 10:12 AM
bjankuski's Avatar
bjankuski
You have added a mini ram (which is known for needing more acceleration fuel) so I believe you are going lean on light throttle tip in. If the problem was there when the car was completly stock you may also have some sort of mechanical or electrical problem that was contributing to the problem. (But when I say stock I mean all stock, if the MAF was gutted that could be enough of a change to cause a bog at light throttle when the engine is cold, with a stock tune).
It sounds to me like your tuner needs to spend more time figuring out the problem and either fixing the mechanical issue or programing it out. (All this takes time and money)
Old Nov 21, 2013 | 01:43 PM
DanielRicany
Okay so I revved it this morning, and it went very lean to the max reading of 22.4:1. It also like backfired and stalled once. Also I should add that some times it takes two tries to start it when it is cold.
Old Nov 21, 2013 | 03:03 PM
383vett's Avatar
383vett
You figured it out!
Old Nov 21, 2013 | 04:08 PM
DanielRicany
Okay, well I set the timing down to 10 degrees BTDC instead of 12, and I got rid of my idle surging for now.
Hopefully this will affect the cold starting problem.
And, the AFR readings at WOT were low 13s, since I did the timing change, the power is similar, but at WOT the readings are mid to high 13s now.
I called TPIS and they said that 12.5:1 is the best.
Old Nov 21, 2013 | 04:17 PM
383vett's Avatar
383vett
As I mentioned earlier, you might want to get an adjustable fuel pressure regulator and increase the fuel pressure. This will give you more fuel in open loop and wot.
Old Nov 21, 2013 | 04:57 PM
hooked073's Avatar
hooked073
what is your temp sensor telling the ecm what the temp is reading? These reading need to be real close to what the engine temp really is or you will have lean and rich conditions also
Old Nov 22, 2013 | 09:16 AM
DanielRicany
The temp sensor is new and the system is functioning properly. I tested it when after I did the engine mods in the beginning because the car was over heating because the computer was going into limp mode. The place that soldered my adapter messed up but they fix it for free. Free shipping too.
To 1985 Bog when revving in open loop
