service code
Old Nov 21, 2013 | 08:32 PM
wingnut96lt4's Avatar
wingnut96lt4
Default service code
Hey anyone tell me another way to kill the service engine lite beside dissconecting the battery? hate to loose the codes
Old Nov 21, 2013 | 10:09 PM
DanielRicany's Avatar
DanielRicany
Disconnect The Unit From Behind. Or, Cut The Wire From The Ecm To The Check Engine Light.
Old Nov 22, 2013 | 03:07 AM
Cliff Harris's Avatar
Cliff Harris
Put a piece of electrical tape over it.
Old Nov 22, 2013 | 07:45 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Here's an interesting thought you might want to consider: Fix the problem(s) that cause the light to come on!
Professor Hugo Fixitnow says it's simple math:"NO problems = NO SES light".
Old Nov 22, 2013 | 09:19 AM
c4cruiser's Avatar
c4cruiser
Year of car? What are the codes? HAve you pulled them yet? You can go to places like AutoZone and they will read the codes for free. Get them and post them here.
Problems that cause the SES light to come on will keep setting codes and turning the light on. Fix the problems and light goes off!
Old Nov 23, 2013 | 11:07 AM
lt4obsesses's Avatar
lt4obsesses
You can also purchase a hand held scanner for about $50-60. These cheaper ones will only display the code and allow you to clear them. If you take the car to a shop, the codes are stored in history and the shop will be able to read them with the more advanced scanning tools. Your car is OBDII by the way.
Old Nov 23, 2013 | 08:10 PM
wingnut96lt4
Default code
Thanks LT4 I will get one. The code is for a charcoal filter up behind the back wheel PITA to get at I just by pass it already did my smog test for this year. One more and no more tests.
To service code
