86 slave cylinder bleeding question
Old Nov 21, 2013 | 11:28 PM
Bensons86's Avatar
Bensons86
Default 86 slave cylinder bleeding question
My car didn't have a problem in the world with the clutch until the motor was removed. At that time, a new throw out bearing was put in, because the old one was making a funny noise. (ok, so it had one problem). Now that it has been put back together, it has been bled 5 times, but there is still 5 inches of slack in the pedal and it won't really go in gear, even when the car is in motion. You can eventually get it in first with enough jockeying, but then the clutch immediately engages right off the floor. It seems the threads say new master and slave cylinders, but since it didn't seem to have any issues prior to the install of the throwout bearing, I wanted to run this past everybody to see if you thought it was still the master/slave or if it could be something else. There isn't some kind of linkage on these that can be adjusted, is there? What are the odds that there is still air in there?
Old Nov 21, 2013 | 11:47 PM
DanielRicany's Avatar
DanielRicany
Hi, Try Removing The Cap On The reservoir And Simply Pumping The Pedal. Do This For Five Minutes. It Worked For Me.
Old Nov 22, 2013 | 02:27 AM
Z51JEFF's Avatar
Z51JEFF
I tried this on my ZR-1,after 1/2 hour gave up and used my Mityvac to bleed the slave cylinder.
Old Nov 22, 2013 | 02:37 AM
94z07fx3's Avatar
94z07fx3
for the self bleeding action to work the slave must be level. So throw a small level on it and jack the car as needed or park on the correct incline. hose comes in from the top so if you get the bore of the slave right the air will float up.
Old Nov 22, 2013 | 09:08 AM
DanielRicany
Maybe every time you bleed it you are leaving the master dry, and then refilling.
Old Nov 22, 2013 | 09:18 AM
Bensons86's Avatar
Bensons86
Is the pedal having free play a common sign of air in the line? Someone else has always done the bleeding, so I don't know if they ran it dry or not. Two different mechanics, so surely they knew what they were doing. I'll try the self bleeding method and see what I can accomplish myself.
Old Nov 23, 2013 | 12:05 PM
Bensons86's Avatar
Bensons86
Ok, opened the reservoir and ended up pumping it in two sets of 300. The first time, it seemed to help, so I dropped the hood for a good trial run, but by then it was grindi.g again in reverse. At first it went in ok. So I killed it and pumped another 300 times. Again, it seemed to work, but when I went to do a run, it again grinded in reverse. Am I making progress or is it an illusion? The oil was clear and not frothy and the levels remained the same. Thanks.
Old Nov 23, 2013 | 01:27 PM
DanielRicany
Reverse gear isn't synchronized on this transmission. That's completely normal, if you start the car, and then without releasing the clutch and try to put it in reverse and it grinds, then you have air still. But if you've been driving already and go to put it in reverse and it grinds then it's normal.
To get around this, you are supposed to put the car in first gear and then reverse. All without releasing the clutch. It shouldn't grind.
Good luck!
Old Nov 24, 2013 | 06:56 AM
hcbph's Avatar
hcbph
Default Bleeding the slave cylinder
After I got my 86 in August the slave cylinder went out.
I had my mechanic change out both the master and slave, he said he worked on bleeding it for something like 4 hours and still didn't get all the air out.
Well I found this video and tried it:
I tried it and I did get some air out, but it turned out I didn't get it all out, still didn't get the clutch to fully disengage.
Talked to a guy that used to be a GM mechanic and he gave me a suggestion - side slipping the clutch.
Pump the clutch up several times and hold the clutch pedal down for around 5 minutes (cap removed from the reservoir), then slide your foot off the clutch and let it pop up on it's own and it can pull some air out of it. I ended up doing this 2 or 3 times with a 15 minute or so delay between each attempt.
In the end I've had a very solid clutch that fully disengages the clutch without any problems and have not had a problem since.
It worked for me, hope that helps.
Paul
PS - this is assuming you have the right parts properly assembled. Worth double checking.
Old Nov 24, 2013 | 03:25 PM
frank j. moran's Avatar
frank j. moran
The best way to bleed this unit is to take it off the bell housing, tilt it to a 45 degree angle, in other words have the bleeder screw at the highest point. Bleed it just like a wheel cylinder, a couple of strokes of the pedel. You have to have the slave bleeder screw elevated so that you can remove the last bit of air.
Old Nov 24, 2013 | 11:53 PM
Bensons86's Avatar
Bensons86
I'll see if I can get out there again tomorrow and play with it. How do you know the difference between a bad slave/master and just having air in the lines?
Old Nov 25, 2013 | 10:18 AM
hcbph's Avatar
hcbph
On the slave vs master, there apparently was visible leakage on mine (the slave).
On air in the line, this is what I did. I couldn't raise the rear wheels at that time, so I blocked the front wheels with some chunks of 4x4 and plenty of space behind me 'just in case'. Started the engine with the transmission in neutral. Depressed the clutch and held it then after about 2 seconds tried shifting into reverse. If there was any grinding, there was still air in the line. When all the air was gone, no grinding into reverse with just depressing the clutch. That was my method to check. I then tried it on the street and it worked.
While working out the air, if my test failed, I'd pump the clutch pedal a half dozen times or so then tried reverse. If it ground initially but not when pumped up, that confirmed some air was still in the line.
Old Nov 26, 2013 | 08:25 PM
Bensons86's Avatar
Bensons86
I pumped it a bunch more times tonight and tried the 5 min hold side slip approach. It's definitely getting better than it was, but still hard to get in gear and grinds badly in reverse (even when going from first to reverse as suggested above). Why are these so painful? Master looks good. No visable leaks....haven't crawed under to check the Slave yet.
Old Nov 26, 2013 | 08:29 PM
DanielRicany
This is the price of owning a corvette!
Old Nov 26, 2013 | 09:06 PM
hcbph's Avatar
hcbph
Default Slave
Because some brain dead engineer decided it was a good idea (or cheaper) to have a nice big 180 over the master cylinder in the line.
That's got to be the main culprit. I figure if I ever have to do it again I'll change out the line for braided so the slave can be moved above the master to bleed that sucker properly.
Wouldn't you just love to make that engineer bleed a few hundred slave cylinders for punishment
To 86 slave cylinder bleeding question
