1986 Heater Core
Smell of coolant and windows fog up. Only thing I found odd was if I let the defrost go while the car sat for 10 minutes the windows cleared and it was fine. Guess the core stopped leaking for a bit?
My question is if there are any hints or tricks or am I set for what I am afraid of? A long bit of laying on my back working.
Wish I never started , but I wish you luck next time I will just by pass this sob.
I took the dash pad off, which makes it easier to get to the top two bolts that hold the heater housing to the firewall. Some people do it by feel from underneath.
The reason why I didn't have to take off the dash because I was able to bend the plastic piece out of the way underneath the dash to slide my hands inside to undo the straps instead of taking apart the whole entire dash apart just to completely remove the plastic piece from over the dash. Of course you have to unbolt some of the stuff out of the way, like the ECM and dash-door support bar. I think that bolt was either a 13mm or 14mm bolt. The you would take out as many 7mm or 10mm bolts off that big plastic cover until you can swing it open and feel the heater core. So what you would then is to bend it open, just try not to break it, insert your hands inside the bent cover, undo the 2 7mm bolts that strap the heater core down, pull the heater core out, and you're done. Do the reverse. It should be easier because now you can backtrack. Sure you can endure some painful bloody scratches along the way when you bend the cover to insert your hands in, but having those cuts are part of a man's job. I'm young and inexperienced as some would happily do dappily say and can do this job, so if a dumb college kid can do it, it shouldn't be too hard to figure out from there. I'd be more than happy to aid someone along the way if you live nearby Kathleen, FL.
In summary:
Halfway drain coolant
Remove seat
Remove under dash kick panel
You'll see the ECM right there so take your 13mm ratchet and extension and remove the 2 bolts that hold it.
Drop ECM
Take off the door control module
Remove that black metal bar that connects the dash to the door so its not in your way
Remove as many bolts as you can from that big black plastic cover that seal the heater core. I think they are either 7mm or 10mm bolts.
As soon as you do that, it will be flexible enough to pry and bend out of the way enough that you can stick you hand in there.
As you are upside down laying on the floor, feel around for bolts that hold the heater core through that plastic piece.
You should feel a strap that holds the bottom of the heater core. It is bolted on by 7mm bolts.
Remove the bolts and strap
Pull out the heater core and your job is halfway through.
Slide in the new heater core and do the reverse of the "underdash" disassembly instructions.
Hope this helps.
http://forums.corvetteforum.com/1569252027-post4.html
A little later in the thread that post came from he posted this picture. I guess he was a little frustrated:
Me too...Info found in this thread --->
