How much will handling improve by lowering it?
Old Jul 8, 2002 | 05:53 PM
n1kki6's Avatar
n1kki6
Default How much will handling improve by lowering it?
I've been thinking about lowering my vette and was wondering if my handling will be noticably better, and also how will the overall ride be effected?
Old Jul 8, 2002 | 06:22 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: How much will handling improve by lowering it? (n1kki6)
When I lowered mine, both handling and ride improved... enough so that my wife noticed and she very rarely drives the car.
Even if it didn't help.. the looks alone are very much worth it! :cool:
I did go down almost two inches thou.
Old Jul 8, 2002 | 09:59 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: How much will handling improve by lowering it? (Springer's 95)
Its gonna look good, be a bit more responsive- but dont kid yourself- it will be rougher.
Old Jul 8, 2002 | 10:08 PM
Springer's LT4
Default Re: How much will handling improve by lowering it? (GusBustamanteJr)
My ride was in no way rougher afterwards... it was quite a bit smoother.
Old Jul 8, 2002 | 10:48 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
What parts did you use? Who did the work?
And more importantly, what would you do differently if you had it to do over?
Old Jul 8, 2002 | 10:58 PM
96LT1's Avatar
96LT1
Just lowering the car won't do a lot to improve handling and in some cases will actually be detremental.
GM spent a lot of time and money in developing the suspension for the C4s. While the later models were "loosened up" to provide a smoother ride, they still handle quite well. By lowering your car, you are changing the dynamics of the system. The rake the C4 has was designed to augment the suspension. Changing the rake (angle) will impact your handling characteristics.
If you are serious about improving you handling then remember you are dealing with the entire suspension package.
Otherwise, if you are doing it for looks that is something else.
Just don't be a ricer (thinking that just lowering your car will improve its performance)
[Flame suit on]I know I'm going to catch flack about that[/Flame suit off]
Old Jul 8, 2002 | 11:25 PM
Springer's LT4
Default Re: How much will handling improve by lowering it? (Fozzy_Bear)
I had a local vette shop do the work using the standard lowering kit availible at most of the vette parts house... cost me $300 including the alignment. If I had to do it over, I wouldn't change a thing... the job came out perfect and i'll never own a C4 that isn't lowered in the future.. it was the best 300 bucks I spent on the car.
It is very possible to lower the car and keep the rake... and most who have lowered just the rear haven't seen any ill effects from it... as most don't drive at the speeds where the rake would come into play.
The handling does improve by just lowering it... it's certainly not night and day, but it is better.
Old Jul 9, 2002 | 01:31 AM
n1kki6's Avatar
n1kki6
i would like to lower the front and rear, i was looking at like the $40 dollar kit like corvette central offers and figured if i could get i little bit better handling for 40 bucks why wouldn't i do it . If i were to lower it how would everyone recommend doing it.
Old Jul 9, 2002 | 01:35 AM
BobMachus's Avatar
BobMachus
I lowered mine last winter in conunction with a poly bushing install. The combination of new poly bushings, lowered ride and good alignment made a HUGE difference on the way my car drove and handled. I can't comment on the effects of just a lowering, but it does look alot better IMO.
Old Jul 9, 2002 | 01:54 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: How much will handling improve by lowering it? (BobMachus)
I lowered my car last month. By using longer rear bolts with Grade 8 Nyloc Locking Nuts. I just lowered the back..about 1¼". I then had it aligned to the specs on Vette Brakes & Products Website (The one that Callaway says is for "Advanced Street") I'll tell you now, the car is DEFINATELY much tighter and handles ALOT better.
Old Jul 9, 2002 | 02:21 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
I work with a few ricers and the one thing that I know from being around them is that you can lower your car correctly, or you can do it ALL WRONG. I don't think there are many "kind of OK" lowering job out there. If you do it right, smooth straights, tight curves, and great looks. Anything less than perfect, and its hammer-to-the-spine straights, body roll and understeer in the curves, and gouges in your sidewalls where the body rubbs the tires.
I don't have any PERSONAL experience though... Anybody here have a lowering experience that was just so-so?
- Fozzy
Old Jul 9, 2002 | 02:38 AM
ToniH's Avatar
ToniH
Default Re: How much will handling improve by lowering it? (TIMSPEED)
I lowered only the rear but did the bushings and other stuff too (in my sig), including the same align specs TIMSPEED is talking. I am very happy with it. It is all about finding a balance that works for you, with luck its easy but in the worst case it can be pain.
ToniH
[Modified by ToniH, 8:50 AM 7/9/2002]
Old Jul 9, 2002 | 02:43 AM
Skippy Stone's Avatar
Skippy Stone
I think 300 bucks is a great price for the work involved. When I lowered mine there were no kits, no how-tos that worked and I was broke as usual so I figured it out for zero. My Conv. is stiffer to begin with, add the heavy duty bars and the front is too rough over pot holes. I have to keep the 11" rears from rubbing.
You get more "push" or "understeer" once lowered. On smooth highway it kicks Porsche tail. Well, just about anything I've raced, actually. BUT, if the alignment is set for speed I run through tires fast. "normal" alignment, they are fine. Oh and drive REALLY slow in/out of driveways and over speed pumps. :crazy:
Old Jul 9, 2002 | 02:59 AM
ToniH's Avatar
ToniH
Default Re: How much will handling improve by lowering it? (Skippy Stone)
> Suspension/Wheels: ZR1-11" (Correct for '90), ZR1 Stabilizer (rear), 52mm stabilizer (front), urethene bushings, lowered 1"
A 52mm sway bar, thats over 2" ??? Surely its a typo and you mean 32mm? I can't figure out how to fit a 52mm bar in there as 32mm was very tight around the shocks (3mm ie. 1/8" clearance). Also can't imagine what a car would be like to drive with such a enormous bar mated with just a tiny (in comparison) ZR-1 rear bar, pushing yourself out of the road in every corner around the town? ;)
ToniH
Old Jul 9, 2002 | 03:11 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I lowered the rear (only) about 1 1/4" and it sometimes bottoms (new shocks??).
The car felt totally different when I first sat in it as well as looked much better with the tires filling the wheel wells.
It seems to launch a little stronger than before and definitely handles and tracks well even with the big 275s up front.
Old Jul 9, 2002 | 09:25 AM
GusBustamanteJr
Default Re: How much will handling improve by lowering it? (65Z01)
My rear almost bottoms over some bumps which hardly affect regular cars- the front definitely bottoms out more often, and there is less bump rubber on there than before, it gives a good jolt. On regular roads, and normal bumps, it just feels a bit stiffer than stock, but all bumps will be heard louder, and felt in the wheel and SOTP much more than stock.
To How much will handling improve by lowering it?
