1991 rollcage needed
Old Nov 27, 2013 | 11:22 AM
TCurtner's Avatar
TCurtner
Default 1991 rollcage needed
Help! Need to get my C4 ZR-1 vette caged. In East TN - looking for someone to install/construct NASA legal rollcage for ST-2 rules. Will also look at SCCA reg builder as option. Any suggestions?
Old Nov 27, 2013 | 03:23 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Any NCCC Corvette clubs in the area, they might know
Old Nov 29, 2013 | 10:17 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Take a look at Autopower cages. You may want to do something different with the door bars, but I have one and it fit pretty well. I did do the NASCAR style door bars in mine though.
Old Nov 30, 2013 | 05:52 PM
TCurtner's Avatar
TCurtner
Thanks guys...will look into both of these...anyone else know of an installer in my general area?
Old Nov 30, 2013 | 05:53 PM
TCurtner's Avatar
TCurtner
Also - do you have pics of yours that you could post a link to?
Old Dec 2, 2013 | 05:41 PM
BrianCunningham
FYI my 6pt started off as an AutoPower 4pt
http://s242.photobucket.com/user/swi...?sort=3&page=1
Old Dec 2, 2013 | 09:58 PM
l98tpi's Avatar
l98tpi
Max G’s
It would probably be best to post in the Autocrossing/RoadRace section. More guys over there running NASA. Sounds like you want an actual cage not a roll bar? I know some guys that could probably help you here in OH, but not in TN.
Old Dec 2, 2013 | 10:29 PM
Black89Z51's Avatar
Black89Z51
Door bars
I'll try to find some more. That's pretty much all I have on photobucket right now.
Old Dec 3, 2013 | 04:41 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I know folks in VA and GA
Old Dec 3, 2013 | 05:33 PM
BrianCunningham
Door bars
Nicely done, those door bars that go into gutted out doors are what you need for wheel-to-wheel racing.
Old Dec 4, 2013 | 10:01 AM
TCurtner's Avatar
TCurtner
Well...let us know! I'm sure I'm not the only one that needs a full roll cage for track work...
VA and GA both close enough to suit for getting this done
Old Dec 5, 2013 | 05:07 PM
Purple92's Avatar
Purple92
A friendly word of advice (from someone who has installed an Autopower Bar) - before you start the install, place the bar that lives over the drivers head in place, and see if you still fit in the driver seat. In my case, my head (with helmet) and the bar, and part of the roof panel all wanted to occupy the same space. That doesn't work !!! I ended up just installing the four point bar - not the 6 point.
Another "tip" is that in order to install the bar - you're going to need to cut through about half a square foot of the SMC interior on each side to get access to the frame for both the bar and for the welder head. A die grinder with a carbide rotary cutter works great (it would help to have someone running a shop vac while you do the cutting - the amount of dust you create is really amazing), but if you have a pristine car - this step is going to bring tears to your eyes.... You can patch up the carpet to look quite good after the bar is installed - but the car won't be weathertight anymore.
To 1991 rollcage needed
