95 HVAC controler
Old Dec 1, 2013 | 05:02 PM
jim95's Avatar
jim95
Default 95 HVAC controler
Does anyone have a schematic for the control board on a 95 HVAC controller? I thing I have a solenoid that's not working. I fixed the vacuum connections and have it set on the dash vents for now but I would like to repair the controller and get it working properly.
Old Dec 2, 2013 | 03:46 AM
Cliff Harris's Avatar
Cliff Harris
I made a schematic of the controller in my car. I know they eliminated some of the solenoids in later years and I believe major changes were made right at the end of C4 production. Maybe this will be helpful:
http://forums.corvetteforum.com/c4-t...schematic.html
Old Dec 2, 2013 | 02:06 PM
pcolt94's Avatar
pcolt94
I got nothing, but would be glad to help if I only had the 95. (I don't think it exists outside of GM).
But I think what you are really asking for is the schematic for the HVAC programmer. (Not control head)
Perhaps you can get a defective programmer and use it for parts.
Old Dec 2, 2013 | 06:06 PM
jim95's Avatar
jim95
My mistake, you are right I need a schematic for the programmer not the control head.
Thanks Jim
Old Dec 2, 2013 | 06:58 PM
Klyde's Avatar
Klyde
I have a manual for a 96' and the wiring diagram is spread over multiple drawings each assigned to the different functions. There are 5-6 just for the C68 Electronic Controls. What section are you needing? There are ones for Blower Control, Power-Communication-A/C Clutch Control, Air Delivery and Vacuum Distribution, and Temperature Control
Old Dec 2, 2013 | 07:07 PM
jim95's Avatar
jim95
Air Delivery, Vacuum Distribution, and Temperature Control
Old Dec 2, 2013 | 07:47 PM
Klyde's Avatar
Klyde
Vacuum
Klyde's Avatar
Klyde
Temperature
Old Dec 2, 2013 | 08:35 PM
pcolt94's Avatar
pcolt94
See if these will help. Not from the FSM but are GM documents.
*I see I posted second but I will leave them up anyway for they may sill be of use.
Jim, did you get your temperature sensor figured out from other post?
Old Dec 2, 2013 | 08:54 PM
jim95's Avatar
jim95
I think so, all I found was dirty contacts.
Thanks Jim
To 95 HVAC controler
