Valvoline ATF ???
Old Jul 9, 2002 | 08:47 AM
Sliding's Avatar
Sliding
Default Valvoline ATF ???
Does anybody use Valvoline ATF Dexron III / Mercon ?
Should this ATF be O.K. for my Vette?
Old Jul 9, 2002 | 11:25 AM
Oh My's Avatar
Oh My
Default Re: Valvoline ATF ??? (Sliding)
At work we are now selling the ATF valvoline max life Dexron III. Is this what you are reffering to? If so, you'll be fine using it. And for information, it is a non synthetic based fluid.
Old Jul 9, 2002 | 11:45 AM
Sliding's Avatar
Sliding
Default Re: Valvoline ATF ??? (Oh My)
On packing is written only Valvoline ATF Dexron III / Mercon.
I saw Valvoline max life engine oil but not ATF.
Old Jul 9, 2002 | 12:22 PM
Corvette0096's Avatar
Corvette0096
Yep that is good stuff. :yesnod:
Old Jul 10, 2002 | 08:42 AM
mj_duell's Avatar
mj_duell
St. Jude Donor '06
I use B&M Trick Shift fluid, best stuff I have ever used. Shift response is more pronounced and drivability seems smoother. It will mix with standard ATF, but I suggest changing it all. I race my automatic and it keeps slightly cooler than when I was using Dextron III. Go to B&M :
http://www.bmracing.com/noflash/index.html
Check it out. :seeya
Old Jul 10, 2002 | 03:51 PM
87Beast's Avatar
87Beast
I just started using this. Seems good so far
To Valvoline ATF ???
