Changing my cam again. Help Needed!
I have a comp cam grind # 280 XFI HR-13
576/571 lift 230/236 @ .050 with a 113 lobe sep
My Mods are: 1992 LT4
P1SC procharger w 8 rib bracket, 2.65 pulley, meth/water injection
12-14 psi at around 6500
Forged 383 10:1 compression, studded with cometic head gaskets
AFR 210 comp port heads with 70cc chambers
Port matched LT4 intake
BBk 58 MM TB
Siemens 60 lb injectors
aeromotive pump and regulator
ARH 1 7/8 step headers with full 3' exhaust
And all the supporting minor stuff. I have a competent tuner with a nice dyno tuning the car for me. Right now I am running the 6 rib pulley from procharger and 7.5 psi. I am going to put Gregs 8 RIB on and pulley down to get somewhere around 12-14psi
I know there is alot more to be had from a better boost friendly cam and I am looking for some suggestions! I was thinking maybe even a custom grind but I need more knowledgeable input from someone that is more competent when it comes to cams. So any advice would be greatly appreciated!
As of now I have the stock D44 with 3.54. Im fairly certain I will break it next year when I throw some stickies on it. If and when that happens, I will upgrade to either a straight axle conversion or that D44 setup thats posted on here when and if they can get it done. They are hoping it holds 1000 whp. If it does, i will buy it. Id like to keep the IRS if I can.
I just posted a vortech V-1s for sale with a fast computer in the for sale section!
Do you have any video of your car idling?
Chris Straub (hes here on the C3 tech board Cstraub69) or Mike Jones aka Cam King found on speedtalk. They will get better results than about anyone else out there. When youre cranking up the boost the "almost right guess" cam can be giving up a lot.
Visit jonescams.com, bullet racing cams or other grinders. Even Bret Bauer, at bret@bauer-racing.com
http://www.compcams.com/Company/CC/c...?csid=216&sb=0
Should make more power than your current cam, earlier intake closing and later exhaust opening and considerably more overlap to scavenge the cylinder.
