tunerpro rt data logging
Old Dec 6, 2013 | 10:04 PM
yorkfitter's Avatar
yorkfitter
Default tunerpro rt data logging
I have an 86 that was built in Dec of 85. I boght the cable from moates to datalog. I go thru the instructions on moates website on how to get the cable working and it checks out. After that I get lost on what files I should be using. Is there a tutorial or another thread that can help me get going? I have been working on this for over 3 hours and cant get anywhere.
Old Dec 7, 2013 | 12:21 AM
Cliff Harris's Avatar
Cliff Harris
You have a 1227165 ECM with a firmware mask ID of $32. You need the template files to make this work. That would the "32.xdf" and "1227165_160.ads" files, found here:
http://tunerpro.net/downloadBinDefs.htm
The ECM spits out a long series of numbers. The files above allow TunerPro to figure out what the numbers mean.
Old Dec 7, 2013 | 07:28 AM
vetteoz's Avatar
vetteoz
Originally Posted by yorkfitter
Is there a tutorial
http://www.gearhead-efi.com/Fuel-Inj...must-read!-%29
http://ls1tech.com/forums/lt1-lt4-mo...-tutorial.html
http://xoptiinside.com/yahoo_site_ad...T.15590439.pdf
http://tunerpro.net/forum/viewtopic.php?t=1014
Old Dec 7, 2013 | 11:00 AM
yorkfitter's Avatar
yorkfitter
What bin file do I use, or do i need one?
Old Dec 7, 2013 | 07:06 PM
vetteoz's Avatar
vetteoz
bin file do i need one?
The bin file is the master file used to run your car
Old Dec 7, 2013 | 08:01 PM
yorkfitter's Avatar
yorkfitter
Do I need a bin file if I am just logging?
Old Dec 8, 2013 | 02:45 AM
Cliff Harris
You only need the bin file to burn a chip.
Old Dec 8, 2013 | 01:14 PM
tunedport85inject's Avatar
tunedport85inject
Do you set up the # port comm in your laptop to connect with TunerproRT.
register yourself here and dowload the .bin file for your 165
http://www.gearhead-efi.com/Fuel-Inj...tion-32,scroll down the page and found .bin file $32 for your platform Y-body
Old Dec 8, 2013 | 01:40 PM
yorkfitter's Avatar
yorkfitter
Is this the only information you get during data loging, or am I missing something?
To tunerpro rt data logging
