MAF question
Old Jul 9, 2002 | 02:25 PM
wz2wj1's Avatar
wz2wj1
Default MAF question
I am think of my next mod??? I am considering a MAF sensor. Any comments on which one or if it is evan worth considering. 94 auto LT1. Also what is WOT?? I know it's probably something simple , i see alot of reference to this in the articles.
thanks
Old Jul 9, 2002 | 02:36 PM
Scooby's Avatar
Scooby
Default Re: MAF question (wz2wj1)
Can't comment on the MAF, but WOT = Wide Open Throttle
Old Jul 9, 2002 | 03:04 PM
vader86's Avatar
vader86
You mean youre considering removing the screens in your current MAF sensor or buying a Granatelli unit?
Old Jul 9, 2002 | 03:21 PM
silver & red CE's Avatar
silver & red CE
MAF mods aren't going to do anything to your ride. It's time to think about catback, 1.6 rockers and springs, cam, headers.
Eric
Old Jul 9, 2002 | 03:34 PM
wz2wj1's Avatar
wz2wj1
Default Re: MAF question (vader86)
I was considering the Granatelli unit?
Old Jul 9, 2002 | 03:36 PM
vader86's Avatar
vader86
might help, best to save the money or buy some 1.6RR though
Old Jul 9, 2002 | 08:53 PM
wz2wj1's Avatar
wz2wj1
Well i decided to remove the screen in the oem unit & see what happens. The screen came out with little or no problem and could be replaced if needed. I only had a chance to drive a couple of miles it's been raining all day. Seems to be better so far ,will give it a few more test drives. But if no problems arise I'll keep it out. The only problem i had was i forgot to hook up the maf sensor and got a service eng light. Once i had that corrected everything was ok. The screen was actually very easy to remove and like i said it's all in one piece and not damaged. :yesnod:
Old Jul 9, 2002 | 10:09 PM
plumberh2o's Avatar
plumberh2o
How did you get the screen out with out hurting it?
I was thinking of doing just that.
Old Jul 9, 2002 | 11:52 PM
LT4POWR's Avatar
LT4POWR
Default Re: MAF question (silver & red CE)
Eric
Old Jul 12, 2002 | 09:18 PM
wz2wj1's Avatar
wz2wj1
Default Re: MAF question (LT4POWR)
I don't think I'll ever take the car to the track, just a summer driver, cause of the weather up here. Of the things you mentioned I don't think I would change the cam. Cat backs sound like a good idea to me, what are 1.6 rr and what would that accomplish? or is that something that you would need to do with the cam change? Is that something I couod do myself?
thanks
Old Jul 12, 2002 | 10:21 PM
silver & red CE
...what are 1.6 rr and what would that accomplish?...Is that something I couod do myself?
1.6 roller rockers (1.6 rr) increase the effective lift and duration of the installed cam (vs factory 1.5 rockers). The factory rockers are stamped and aren't even 1.5, more like 1.4. The roller part is that there are bearings at the pivot and valve tip, lowering friction. Between the lower friction and the higher effective lift and duration, you'll see about 10 HP at the rear wheels. This mod requires the factory springs be changed at the same time the 1.6 rr are added. Total cost is ~$350 in parts. If you're a DIY kind of Vette owner, it's easy to do yourself.
Eric
Old Jul 12, 2002 | 10:55 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
I took mine out about a year ago and I have never had any problems. I have since put about 15000 miles on the car. I have driven to Texas, twice and Florida twice from North Carolina and New Jersey once. Any little bit helps in my book. :cool:
Old Jul 12, 2002 | 10:59 PM
wz2wj1's Avatar
wz2wj1
How long would something like this take? And where would you get a procedure . Or is it straight forward once valve covers have been removed?
Old Jul 12, 2002 | 11:07 PM
silver & red CE
I used the Factory Service Manual and the Haynes manual as my references. The hardest thing is learning to lash hydralic lifters. Takes a little work, but it's worth it.
Eric
Old Jul 12, 2002 | 11:24 PM
wz2wj1's Avatar
wz2wj1
In you're opinion what would be better to do the cat back or the 1.6 rr & springs? I just looked under the hood do you have to remove the alt bracket to get the drivers side cover off?
Old Jul 12, 2002 | 11:32 PM
silver & red CE
I'm not smart enough to know what's better. Me, I'd do both, but I'm a terminal case. Long term you'll want to do both anyway, let your budget decide.
Yea, it's a bit of a pain, but worth it.
Eric
Old Jul 14, 2002 | 11:27 AM
wz2wj1's Avatar
wz2wj1
couple more questions
I got the haynes manual.
1. did you have to raise the car to remove a bracket from each valve cover?
2. How did you turn the engine over to adjust the lash on each rocker?
Cat Back Question.
1. WHich one ?
2. One with or w/o a resonator
To MAF question
