need a little visor help
Old Dec 7, 2013 | 01:48 PM
rick lambert's Avatar
rick lambert
Default need a little visor help
This is for my 87 coupe. I'm getting a guy to re cover them, the drivers side came off easy....but the passenger side has the mirror and lights...I really don't want to cut the wiring, has anyone removed them before? Thanks in advance.
Old Dec 7, 2013 | 02:38 PM
Drycreek's Avatar
Drycreek
Under the header moulding there will be a wire connector that just unplugs.
Old Dec 10, 2013 | 09:38 PM
rick lambert
ttt
I can't seem to see/read only your reply.
Old Dec 10, 2013 | 09:41 PM
rick lambert
Funny, but now I can see your reply. Thanks. But what do you mean by "Header moulding" ?
Old Dec 10, 2013 | 10:11 PM
Klyde's Avatar
Klyde
The piece of plastic above the windshield. The wires on the visors go under/inside this cover and there is a push in connector. The wires are only a foot long and then the connector. Remove the header cover and you will be able to get to the connector. It is small enough to fit through the visor hole.
To need a little visor help
