ALCL Question
Old Dec 7, 2013 | 03:26 PM
cumbercr's Avatar
cumbercr
Default ALCL Question
Does anyone know which pin on the ALCL connector has the data for data logging? I replaced my 870 ECM with a 165 and I am now trying to data log. The engine runs OK but I can't establish a connection with DataMaster or TunerPro RT. If I know which pin the data is on I can possibly trace back to a bad connection from the swap.
Old Dec 7, 2013 | 03:31 PM
tequilaboy's Avatar
tequilaboy
Pin E
http://members.shaw.ca/corvette86/En...agram%2086.pdf
Question: If you can't log now, how did you know what your injector pw and blm values were in your other threads?
Old Dec 7, 2013 | 04:51 PM
cumbercr's Avatar
cumbercr
Originally Posted by tequilaboy
Pin E
I was able to log for a while. But now there's nothing. That's what leads me to believe it's a bad connection.
Old Dec 7, 2013 | 05:49 PM
cumbercr's Avatar
cumbercr
Pin E
By the way, the electrical diagrams are very helpful. I just verified I have voltage on Pin E. So I suspect the serial terminal is not the problem.
To ALCL Question
