Tranny shift in .4 seconds .... :)
Old Jul 9, 2002 | 04:24 PM
GlockLT4's Avatar
GlockLT4
Default Tranny shift in .4 seconds .... :)
I just thought I would brag for those of us with automatics. Sure I wouldn't mind a 6spd, but this is awesome to me. BTW, I have a rebuilt transmission with some go fast parts like a TransGo Shift kit. :yesnod:
Graph one:
notice we are at record # 1274
Graph two:
notice we are at record # 1276
Datamaster is recording at 10 records per second alternating engine and tranny data, which means this tranny data is going at 5 records per second. 2/5 = .4 seconds :D
Chirps the tires every time :D :smash: :smash: :smash:
edit: .6 seconds, see below.
[Modified by Glock'94, 2:54 PM 7/9/2002]
[Modified by Glock'94, 2:32 PM 7/10/2002]
Old Jul 9, 2002 | 04:59 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Tranny shift in .4 seconds .... :) (Glock'94)
glock. where is the manual to read that graph? :confused: :crazy: :jester
Old Jul 9, 2002 | 05:06 PM
GlockLT4's Avatar
GlockLT4
Default Re: Tranny shift in .4 seconds .... :) (yoslambo1@cs.com)
I don't think there is one.
Old Jul 9, 2002 | 06:38 PM
Timmy!'s Avatar
Timmy!
Did you change any of your tranny programming yet? I did some stuff to mine and I must say that GM makes some impressive tranny's! I amaze people all the time when I show them what my car can do and how fast the tranny shifts.
Old Jul 9, 2002 | 06:40 PM
GlockLT4's Avatar
GlockLT4
Default Re: Tranny shift in .4 seconds .... :) (Timmy!)
I haven't touched the tranny programming. :D
[Modified by Glock'94, 4:40 PM 7/9/2002]
Old Jul 9, 2002 | 06:44 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I think :crazy: :crazy:
Old Jul 9, 2002 | 06:51 PM
GlockLT4's Avatar
GlockLT4
Oops, i made a mistake, the transmission lets go of 1st gear one record before that, so it's actually .6 seconds for the shift to take place. The rpm's go up just slightly when it lets go of 1st.
btw, this run was only at 70% throttle ;)
Old Jul 10, 2002 | 04:26 AM
merrick's Avatar
merrick
I bet I can shift that fast! Cool program, what is it? :p:
Old Jul 10, 2002 | 04:44 AM
GlockLT4's Avatar
GlockLT4
Default Re: Tranny shift in .4 seconds .... :) (merrick)
Datamaster . The all time best data logging program I've ever seen.
Old Jul 10, 2002 | 03:52 PM
merrick's Avatar
merrick
So do you plug into the ALDL connector with a laptop or does it have it's own device?
Old Jul 10, 2002 | 04:03 PM
GlockLT4's Avatar
GlockLT4
ALDL with laptop. :yesnod:
Old Jul 11, 2002 | 01:42 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You can probably make it shift faster but the rest of the drive line will not be too happy about it. I had a THM 350 shift kit that would shift so fast the trans would complete its shifting before the rear wheels even knew anything had happened. A chipped pinion gear tooth and one broken U joint later, I went to a step below 'street and strip' on the first to second shift.
Old Jul 11, 2002 | 01:55 AM
R23HTC's Avatar
R23HTC
If you'd shut off the ASR it might do more than just chirp them! :jester :jester :jester
The year before last when I replaced my clutch, I powershifted to 2nd and dang near got sideways because I wasn't expecting the tires to spin so much! :eek:
Old Jul 11, 2002 | 01:57 AM
GlockLT4's Avatar
GlockLT4
Default Re: Tranny shift in .4 seconds .... :) (R94 LT 1)
HEY! good idea! :lol: :lol: :D :D :D
Old Jul 11, 2002 | 02:18 AM
GlockLT4's Avatar
GlockLT4
wait, that could be dangerous, lol
Old Jul 11, 2002 | 07:57 PM
mackeyred96
You can even hear my new Frank Fernandez trans shift it so smooth.
But the real trick with these transmissions is not how hard they shift, you can control that with line pressure but the sercret is how FAST IT COMES OUT OF GEAR before it up shifts.
To Tranny shift in .4 seconds .... :)
