Brake Bleeding on a 1991 C4
Thanks!
I would suggest using a pressure bleeder and doing one wheel at a time. It sounds like a complete flush will be in order and it will certainly take less time to do. Figure on using about 3 pints. Before starting, use a turkey baster ($3 at grocery stores) to suck out as much of the old fluid as you can from the MC reservoir. Just don't go below the holes going into the MC.
Another suggestion is to get a set of Speed Bleeders for the calipers. These bleeders have a spring-loaded check ball in them. You install the bleeder so it's snug, then back off a 1/4 to 1/2 turn and then simply depress the brake pedal to force fluid past the check ball. As soon as you release the pedal, the check ball closes the bleeder. This makes it very easy for one person to do caliper bleeding or complete flushes.
If the flex hoses are original or something like 7-10 years old, I would recommend replacing all 4 hoses as part of the work.
probably, DOT 3.
Extensive pedal travel may be attributed to: worn brake pads, fluid loss, air in system, faulty master cylinder.
Changing fluid may not solve your problem
But do as you wish.
DUB
I personally would not adjust the rod...unless I have measured it carefully so I am not actuating the master cylinder due to the rod being adjusted out too far. The only time I usually adjust the rod is when a new booster is being installed and I carefully measure and adjust it....or if a master cylinder is being replaced and I check to make sure that the depth of the valving of the master cylinder is equal to the factory master cylinder that was on the car originally.
DUB
p.s. Worn brake pads will not cause excessive pedal travel. Disc brakes automatically adjust for brake pad wear. Another point: In any static hydraulic system, the fluid pressure will be the same at any point in the system. Soft brake hoses will not reduce the pressure in the calipers. They will only give you a spongy feel to the brake pedal. The brakes will stop the car the same with either the stainless braided lines or rubber lines.
Your philosophy on this issue "might be true" except for the fact IF the adjustment for the push rod is already out to far...or it was threaded out further... "just because" ...and this added length in the push rod actually begins actuating the master cylinder. Then the piston valving in the master cylinder would obviously move when you pressed the brake pedal because it is already contacting the piston valve.....which would be incorrectly adjusted by your description of "checking the correct length of the push rod".
Pre-loading or pre-actuation the master cylinder is dangerous and can cause issues that I have had to repair in the past due to parts replacements and adjustment to the push rod was not checked and verified by precise measuring equipment.
I measure this area so it is correct. Just watching the movement of the piston valving does not work in my scenario. I HAVE TO BE more precise than this due to the fact that I am liable of my work. And I am super picky when it comes to a person brakes on their car. And I have repaired brake systems that somebody else attempted and completely screwed it up by turning and changing things that they should not touch due to not knowing anything about it. I have repaired brakes systems where the owner has poured engine oil in the master cylinder....and finished one today where the owner poured DEX-COOL coolant in the master cylinder. Some people can buy a car...but still refuse to read the owners manual. Figure that.
Then I also install a brake pressure gauge so I can actually read the pressure at each wheel if needed. It takes the guess work out on how well the system is operating.
DUB
Then this is when I use my brake pressure tester to verify pressures at each caliper if needed or even at the master cylinder.
I wonder if it is really you writing this or you let someone in your family get on and reply under your screen name just to be "funny". Or your computer has been "hacked". This must be a joke...except for the last quoted comment from you. It just does not make sense. Let's see....you are 30 year ASE Master Mechanic...and instructor for 25 years...and you actually believe (and possibly instruct others) that your procedures are better than the procedures that the engineers that developed the brake systems in cars today and have developed service procedures that would allow a mechanic service it as it needs to be for safety and performance. Because we are talking about a Corvette that does have an ABS unit in this post. And if you have been a mechanic as long as you stated...then would it not seem that you would know how to spell the words correctly for the components/procedures in the system that you know about and teach???
Check your computer or stop allowing someone else respond for you. Because this can not really be you. Joke is over. Seriously.
DUB
"Soft brake hoses will not reduce the pressure in the calipers. They will only give you a spongy feel to the brake pedal. The brakes will stop the car the same with either the stainless braided lines or rubber lines."
This is true only to a point. Once the calipers push the pads against the disc pressure starts to build. Once the pressure reaches the point where the soft rubber hoses swell then the pressure stops building until the hoses quit swelling. Then it builds again. If the hoses are totally shot you could run out of pedal travel before the swelling stops. Therefore worn stock rubber hoses could not only make your pedal spongy but could in theory lower your braking power. Of course the soft rubber could swell till it ruptures leading to zero pressure in that caliper.
On my car over half of the pedal travel was going into swelling all four of my seventeen year old hoses. Once I changed them to stainless lines my braking was greatly improved. They do and did make a difference in braking power and are not the same as the old rubber lines. I'm sure that comparing new rubber lines with new stainless lines there would be little difference between the two.
They are very easy to use!...
These bleeders have a better design than the Russel Speed Bleeder brand IMO...
Once people allow their emotions to override their intellect...and it becomes vulgar....that is when I kinda have to "bow-out" because it just is pointless. I can not communicate with people who are....
DUB
I am quite aware that MANUAL BLEEDING by pressing on the brake pedal is an approved method. The main issue when manually bleeding is to make sure all of the air is out of the master cylinder and then follow the procedures outlined. Also it can be time consuming due to the process...and from my experiences a very long time ago. Having a question if the system was air free was something that I did not like to ask myself. So I bought the diaphragm pressure bleeder and have not looked back.
I feel it all has to do with INTEGRITY. Just because you know this or that or do this or that or even have a tool that can do this or that. It is the obligation of a professional mechanic to have integrity and not settle in to practices that often times may question that integrity. I have turned away more work due to customers want me to do a "half-baked" repair and I just won't do it. I am not implying anyone here on the Forum does that...I am just stating what I DO.
DUB
