Intake leak
Old Jul 9, 2002 | 11:36 PM
Ricks1989Roadster's Avatar
Ricks1989Roadster
Default Intake leak
Hey all, I have discovered a small leak on my intake manifold. The first sign was the hiss of steam after shutting the motor off. Second suspect was the small residue of coolent on the manifold. It is not a major concern right now. However, I would like to know how much time is involved in removing and replacing the gasket? As long as everything is off, do you guys recommend any other things?
Thanks,
Old Jul 10, 2002 | 12:17 AM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: Intake leak (Ricks1989Roadster)
If you haven't ever done it before probally 4-6 hours. It's not to difficult. Just a bit time consuming. While you have it apart you may want to clean the TB, manifold, runners, and plenium. Now would also be a go time to remove the extra bumps in the plenium.
Old Jul 10, 2002 | 10:21 AM
Vic'89's Avatar
Vic'89
Default Re: Intake leak (85WHITEZ51)
Give yourself a full day if you have never done this job before.
Lots of little items have to come off in order to pull the lower intake.
BTW, the dealer charges about $400 - $500 for this job.
Vic
Old Jul 10, 2002 | 08:56 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Intake leak (Vic'89)
:cheers: In my recent experience, once it starts leaking, even a little, it isn't long before it leaks a lot!
If I were you, I would be prepared to move quickly on this
Jack
Old Jul 10, 2002 | 10:51 PM
87SAM's Avatar
87SAM
Well, you heard from all the quick at wrench people, now at the other end of the spectrum. I work slow (on my own time anyway), but it wasn’t prime drive'n time. Took me 3 weekends :eek: but I like to take stuff off, look at it, marvel at it. Next thing you know, you want to have the injectors sent out for cleaning/tested, replace a few sensors and switches, repaint some valve covers, spiff things up, have a couple beverages in the evening and just stare at it :crazy: Oh! Wait, I digress. Ya, what the others said if you go it! :D
Old Jul 10, 2002 | 11:43 PM
Ricks1989Roadster
Thanks to everyone for thier replys. My dad is a retired mechanic and has all those nifty tools. Since it isn't my daily driver, I will work on it over there.
Thanks again.
To Intake leak
