Vacuum Pump?
Old Dec 17, 2013 | 02:04 AM
jemidyette's Avatar
jemidyette
Default Vacuum Pump?
Hey guys,
Finishing up the engine build on my 95 LT1. It's a 383 Stroker with ported heads/valves, full exhaust, headers, bla, bla, bla. Should be upwards of at least 420 hp. Anyway, before the 383 rebuild, I had a ring go bad I believe, and was having serious vacuum/crankcase pressure issues. There weren't any vacuum leaks at that time. I believe the ring went because the engine already had 110,000 miles, and then I decided to do a cam/heads/exhaust job on it, and it just wasn't up to the task. So my question is......
At what point should one decide on getting a vacuum pump, and what are the options out there (electric vs belt-driven). Just curious what the future may hold.....
Old Dec 17, 2013 | 07:53 AM
WW7's Avatar
WW7
Some reading for you...WW
http://www.gregsengine.com/using-a-vacuum-gauge.html
Old Dec 17, 2013 | 09:11 AM
C409's Avatar
C409
..... Very helpful info on the link ... useful for stock engines ........ performance cams have increased duration and overlap which will decrease the vacuum readings at idle ... a vacuum pump or reservoir is needed when the reduced vacuum at idle and low engine speeds starts to affect the performance of the brake booster and the braking action ..........
Old Dec 17, 2013 | 10:33 AM
jemidyette's Avatar
jemidyette
Originally Posted by WW7
Great info there! I don't know why my sig isn't showing, but my cam is a lunati 243/251 .597/.603 110 lsa. I can imagine this much overlap causing an issue. With my old 224/230 it didn't affect the breaks too badly. I just had major blowby issues. I'll report back in a month when I get it all put back in my car
Old Dec 17, 2013 | 02:08 PM
C409's Avatar
C409
............ I have a 248/254 solid roller idling @ 850rpm with plenty of vacuum for the brakes .........
Old Dec 17, 2013 | 02:17 PM
rklessdriver's Avatar
rklessdriver
I thought you were talking about a vacuum pump for the engine...
I don't think you will have any power brake issues with that cam. I run something similar in my 92 and have plenty of power brakes with the stock booster.
Will
Old Dec 17, 2013 | 02:35 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
When you get older, the title for this thread could mean anything!
FWIW: I'm also tempted to say this was a "little" humor!
To Vacuum Pump?
