I checked it again and it appears that I may have over filled it by a little less than half a quart.
I swear the first time around it was right at the add line.
Does the cold have anything to do with the oil level? I think it was like 30 degrees Fahrenheit the other day when I checked it.
Temperature won't affect oil level, just make sure to check it before starting, or when it has sat a few minutes after being ran long enough to warm up. If you just run it for a moment(not long enough to warm up) you will have to wait longer to check the oil. Temperature WILL change how long it takes for all of the oil to get back in the pan.
