cruzin again
It now has a skip from sitting up for a year, gas jelled, clogged the injectors. Chevy folks say run a couple of tanks of gas thru it. I;m on my 2nd, but it still has a skip. This is most pronounced when decelerating. I shift into neutral, because it may break a motor mount. Running Marvel Mystery oil in my gas. skip is some better, but still there.
I highly recommend if you are changing a opti, go ahead and change the ICM. It's been posted here many times before.
I hope after driving around some, things will be normal again.
