93 C4 100k Service?
Old Dec 21, 2013 | 09:33 PM
49er's Avatar
49er
Default 93 C4 100k Service?
Hi All!
I have been learning a lot from this forum over the years (thank you all!). I have finally joined and need to seek some specific advice.
I have a 93 C4 that is just approaching 100k miles. I have owned it 10 years and put 30k miles on it. I am about to replace the plugs and wires, but wonder what else I should do as PM for the ignition system. Should I mess with the opti and replace the cap and rotor too? I don't know if it has ever been touched.
What else needs to be done?
Thanks for any advice!
Old Dec 21, 2013 | 09:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
if it isnt broke they say...
Check basics. Ujoints, wheel bearings for play, front end items fluids etc etc.
Old Dec 21, 2013 | 09:52 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Change all fluids: trans, diff, ps, brake, coolant. (Unless they have been done recently.)
Consider replacing the Multec injectors with Bosch III.
Check suspension bushings for rot. Replace as needed.
If your tires are more than 6 years old, consider replacing.
Old Dec 21, 2013 | 10:20 PM
Kevova's Avatar
Kevova
I would leave opti alone since removing water pump is involved. L98 is another matter since distributor is in the open. At 10 years replacing most fluids would be a good idea.
Old Dec 21, 2013 | 10:49 PM
don hall's Avatar
don hall
If you own an Owner's Manual, there is a helpful list of items to be serviced based on mileage...... the items are listed under MAINTENACE.
If you don't own an Owner's Manual, you might check ebay regularly.
Old Dec 22, 2013 | 03:12 PM
49er's Avatar
49er
Thanks to all of you for the advice! I'll leave the Opti alone and get to work!
Old Dec 22, 2013 | 03:27 PM
armysnipe's Avatar
armysnipe
Fuel filter replacement too.
Old Dec 24, 2013 | 09:58 AM
pcolt94's Avatar
pcolt94
If you are going to do the wires, you will probably need a set of wire holders. Most likely many will break when you remove the wires from them. Or you can just do the job and find out what breaks and then replace only them.
You might need to remove the belt and some other items to get to the left side wires. It is pretty tight in there and wire length is at a minimum and not much wiggle room to get them back on.
I did my wires the first time I did the opti which made thing a whole lot easier. You will definitely work at getting those wires back on.
Good advice to leave the opti alone if it's still running good. I would stay alert and check the bottom of the pump from time to time to make sure it is not leaking.
To 93 C4 100k Service?
