check engine soon, code 36
Old Dec 30, 2013 | 05:35 PM
godfather4's Avatar
godfather4
8th Gear
Default check engine soon, code 36
can someone help with finding the two relays for the maf and burn out relays on my 92 LT1, checked behind the battery area but cant see them, light seems to come on mainly on lifting off the throttle but can be random also, code 36 is the only one showing on the self diagnosis cheers for the new year, paul the mad kiwi
Old Dec 30, 2013 | 06:19 PM
eatmydst1234's Avatar
eatmydst1234
code 36 on an LT1 is a loss of high resolution signal from optispark. usually indicates a failing optispark.
Old Dec 30, 2013 | 10:59 PM
godfather4's Avatar
godfather4
8th Gear
thanks for the info will have to locate one probably from usa and freight it downunder to nz hope fully it will last a couple of months as its summer here and their is heaps happening cheers paul
To check engine soon, code 36
