Shocks how the helll &^%#@behind%
Old Jul 10, 2002 | 08:04 PM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Shocks how the helll &^%#@behind%
Is there a special tool I need to hold the damn bolt while I loosen the nut at the top of the shock any tricks its pissing me off.. :mad
Old Jul 10, 2002 | 08:33 PM
Lord Odin's Avatar
Lord Odin
Default Re: Shocks how the helll &^%#@behind% (AshleyRL-87Conv)
Yeah, I had the same problem until I figured it out on the 2nd shock. Put the car on stands (or a lift if you have one) and then place a jack under the strut and jack it up a little. It'll relieve the pressure from the struts and will let you work on it easier.
[Modified by Lord Odin, 6:34 PM 7/10/2002]
Mo_Bandy's Avatar
Mo_Bandy
Yes they are a pain...
I used vise grips to keep the shaft from turning. I beleive you can pick up a shock tool at any parts store as well. The vise grips always worked for me.. or I've just been lucky...
Mo
Old Jul 10, 2002 | 08:34 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Um...which shock? Front or rear?
I didn't need anything but a couple of wrenches when I did my rears.
Old Jul 10, 2002 | 10:42 PM
Topload's Avatar
Topload
Didn't even waste my time trying to turn them off - just looking at them I could tell they were rusted in place. Used a nut cutter and they cracked in half with a couple of turns - problem solved and it didn't even scar the threads on the shaft.
:seeya
[Modified by Topload, 8:43 PM 7/10/2002]
Old Jul 10, 2002 | 10:44 PM
Topload's Avatar
Topload
Didn't even waste my time trying to turn them off - just looking at them I could tell they were rusted in place. Just used a nut cutter and they cracked in half with just a couple of turns - problem solved and it didn't even scar the threads on the shaft.
:seeya
Old Jul 11, 2002 | 12:04 AM
Boo383's Avatar
Boo383
On certain brands a 1/4" wrench will work, but using a 1/4" wrench isn't the easiest thing to hold on to when torquing, but it worked for me.
Old Jul 11, 2002 | 07:23 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I had to use a hack saw to cut the spindle off of mine. I drove a screw driver between the nut and the washer to open a gap and inserted the saw there. Good luck. :seeya
Old Jul 11, 2002 | 02:26 PM
RichAshley-Black99
Default Re: Shocks how the helll &^%#@behind% (joecaver)
Well hell, sounds like Im going to have a good time pulling them going to be a PIA Thanks for everyones input!! Ill see what works best this wekend :cuss :cuss :cuss
To Shocks how the helll &^%#@behind%
