rough idle
Old Jul 10, 2002 | 09:51 PM
Kdrhpe's Avatar
Kdrhpe
Default rough idle
Well I replaced the plugs which helped but didn't fix the situation. I was figuring on the wires next. Is that a tough job? If that doesn't fix it what should my next move be? How about upgrading to an MSD ignition system. Does that give you any performance gains?
Old Jul 11, 2002 | 12:01 PM
kkonen's Avatar
kkonen
Default Re: rough idle (Kdrhpe)
What year is your car? It could be a bad ignition system. It could also be bad O2 sensors. My Opti went and fouled my O2 sensors, causing the rough idle. What did your old plugs look like when you changed them? Is your car throwing any codes? The car can have trouble codes that do not cause the SES light to come on.
Your car should run right with all factory parts (or replacement) unless you have a heavily modifed engine. I would try and find the problem with what you have before buying something like an MSD box.
Old Jul 11, 2002 | 10:21 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: rough idle (kkonen)
A bad egr valve can cause rough idle also.
Old Jul 12, 2002 | 09:19 AM
Kdrhpe's Avatar
Kdrhpe
The car is a 95 LT1 with 68k miles. I don't have a code scanner yet but I am going to get one soon. Can anybody recommend a good one? The car is stock for now. I'll have to look at the plugs again for a better description but they appeared ok. I remember some faint white residue on a few of the electrodes. How do you know if the opti goes? Won't it give you more symptoms than just a rough idle?
Getting the MSD box isn't to cure the problem, I was just wondering what advantages it gives you. Does it give you anything for a stock set up or is it primarily for heavily modified engines?
Old Jul 12, 2002 | 10:30 AM
Greenvette's Avatar
Greenvette
An MSD box will work for stock and modified engines. However, you have something else malfunctioning in your car. Getting a scanner would be a big help so you done not throw parts at the car which you do not need. Rough idle can be many things.
Old Jul 12, 2002 | 11:36 AM
kkonen's Avatar
kkonen
A bad ignition system tends to show itself with a rough idle and hesitation on acceleration. When my opti went, it backfired on acceleration.
I am not an expert on reading spark plugs. I think that white residue is coolant. Coolant on a spark plug probably means a bad head gasket. Hopefully someone else will answer this, but I think you need a compression and leakdown test. Do you ever get white smoke out the tailpipes?
To rough idle
