I was going to ask the same thing :lol:
I have a 85 that was rebuilt last year and it held steady at 70lb's then this year it started to bounce al over the place 60lb's at the most and when warm drop to 20 or less at a stop then go up when I take off . I just changed the sending unit and it still droppes off is this normal :confused:
My oil pressure seems to drop off at idle which is to be expected from my prior expereince with smallblock chevy engines. I have 90K on my '94 and was wondering what pressure you were running at idle also.
My analog guage sits about 1/4 at idle and just over 1/2 at about 1800-2000 rpm. Also - do you guys get a psi reading for oil on your digital guage? I only get water temp, oil temp, and volts. Is mine broke or do I need to do something else to get that display? Still without an owners manual.
Just wandering if the weight of oil used will affect the oil pressure much? I am using 5W-30 right now. Would changing oil weight help raise my oil pressure? Is this really a problem having low oil pressure? Seems that everyone has alittle different reading. My Vette also has about 130,000 miles on it. Thanks for all the replies!
Might raise it a little, but mine was the same with 10w30 and 5w30 and even 20w50. I think you might have a problem with the oil pump.
I changed my oil using 5w-30 and my pressure was way low, down to 6psi idle but at 40psi at cruise when oil temp was about 200f. I changed to 20w-50 and now I am at 20psi/idle and 38-42psi/gas same temp. :rolleyes:
