I want .3
Give some ideas and no Im not going to spray it.
It would be tough for just a cam change to pick up .3 on the big end... the big end of the track is the hardest place to pick up ET.
Yes I feel I could pick you up with a cam change but I wouldn't guarantee 3 tenths.
The thing is when chasing ET everything is in the 1st half and the 60ft.... That is traction. For traction your gonna need some Drag Radials to get that 60ft down. The more power you out to it early the harder to hook up it's gonna be.
With what your telling me about your launch now.... I would tell you to go and spend $450 on a set of MT Drag Radials and I bet that will get you where you what to be.
Will
I think with good street tires and a well prepped track you could get there.
. I'd rather do converter and a cam. Somebody recommend a cam that will get me the max from my head/intake set up ??
I'm not big on nitruos myself it's too easy and that leads tah trouble for most people, they want more and jet up. You want .3 maybe a shift kit, take 100lbs out, 1.6 rockers if you haven't done all 3 yet.
has that been explored to the limits of the hard parts installed now?
You have some nice stuff inside already. IMO, you should be in the mid 12s now. I think the gear is the ONLY thing holding it back. If you want to keep that, and I WOULD for a DD, I go with:
.... tires, tune and shed some weight. Its pretty easy to drop 2-300 lbs from the interior. It can ALL be reinstalled too.
May not be pretty but everybody will be looking at the slip, not the upholstery !
You gotta know that matching cam lift to head flow characteristics will maximize power.
If you run something like a superram cam, I'm wondering if you can get an extra .2 from the added lift and intake duration?
Then maybe get the other .1 thru weight reduction/cold air? Pull the driver's seat, spare tire, and have your 98# wife/girlfriend nail it down the track when it's 12 degrees outside!
What about pulleys, fresh tires, air foil, thinner motor oil, frisbee, cut-plugs, and clean air filter?
What's your compression? Could you throw more timing and run higher octane? Or, run lower octane with your current timing? What about 100% gasoline -- since it has more BTUs?
Running 93 octane, 10.6 compression. Cam and converter or gears may be the answer.
With the 180 AFR's and the mini ram your OK staying with a 3.07 gear IMO.
I also think the D36 will be fine for a while with the power you going to make... As long as it's in good shape right now.
I see you getting the 60ft down into the low 1.70's maybe high 1.60's. You need to check you clutch pack break away TQ and start keeping record of it everytime you go to the track... this way you can spot a problem before it grenades.
Will
Will
How much do you think I can gain wit the cam, valvetrain upgrade ?
Confession.
A year from now I may be going C6, thats why I hate to buy gears and the converter.
Staying with 1.5 rockers I would recomend something like.
272/280@.006
218/227@.050
.562/.562 w 1.5 ratio
108 ICL 112 LSA
This is a custom grind from Mike Jones' "HR" series lobes. It would haul the mail in your stuff with right converter and a good tune.
Will
Stickier tires will get you two tenths.
