I am looking to upgrade to a better shock on my 92 and I was wondering if anyone has any experience with these Qa1s, ridetech, or the flaming river dual adjustables?
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
None that I know of.
I contacted a QA1 rep shop in Sacramento who confirmed the at rest/travel could not be customized for my lowered 86.
Had to return the set I got and now running Bilsteins.
It seems the extended/retracted length between the 3 all very from a 15.5" & 10.5" roughly to a 14.5" & 9.5"... I wonder what the stock FX3 extended and retracted lengths are. Guess I will measure them tomorrow.
So 86 is different than the later c4s? Does anyone on here have qa1's on their lowered c4? I know guys use them with the coil over setups all the time.
Im running the hal ts508 front qa1 single adjustable on my autox car (lowered). Couldn't use the stock ones because they bottomed out. These are about an inch or so shorter and i have almost 2 inches of play at rest.
Jegs and Summit list the TS508 for the 63-82 Vette. What year is your car that you're using then on? Does this model number work on C4's? My 89 is lowered and I want these shocks too.
Summit list TS403 as 63-82 or 84-87 corvette and a C3 member told me hs is running the TS403, I only noticed whne I looked em up for my C3 that it says early C4's.
edit: I see the diff now TS403 rear, TS508 front
Reason: dirrrrrrrrr
