Hey guys so I've got my 92' 6 speed vette that I'm looking to make faster. In your opinions what's the most bang for your buck becides spraying. And anybody have a tuning suggestion?
Current mods:
-Lightweight flywheel
-SPEC stage one clutch
-short shifter kit
-drop in K&N
-hooker shortie headers
- high flow cats
-full magnaflow cat back
So I thought the LT1 had roller rockers already.
If I did heads/cam how would I tune it?
What gears would you run to still have it street friendly? Would like a 4.10 be overkill?
And the thought of an electric waterpump scares the hell out of me. What advantage will it get me?
Elect water pump would be a option.
4.10 gears is something that should have come stock with all LT1/M6s and LT4s.
Roller rockers came only with the LT4s
You can do a Hot Cam set up like above, or if you want a little bit more power, go with a bigger cam or heads.....and if your still not happy, you can always stroke.
I didn't install them, was on the car when I bought it. I want to do long tubes.
I'm pretty sure they did not come with 4.10's.
How would I tune for the cam?
