fidanza flywheel
Old Jan 5, 2014 | 12:08 AM
david frederick's Avatar
david frederick
Default fidanza flywheel
Does any one know the difference between l98 #198581 and the lt1#198501 fidanza flywheels cannot find the specs. thankyou.
Old Jan 5, 2014 | 05:04 AM
WVZR-1's Avatar
WVZR-1
The 198581 is actually an F - body application for LT1
The 198501 is a, '89+ ZF DMF replacement except LT5
One you don't mention is a 198531 which is I believe for '86 - '88 1PC RMS applications
I believe the Fidanza application guides mistakenly reference an LT1 as '89+
Old Jan 5, 2014 | 06:18 AM
david frederick
tks. need to know the diference between f-body and zf replacement flywheel again tks.
Old Jan 5, 2014 | 08:31 AM
WVZR-1's Avatar
WVZR-1
Aside from the advertised weight difference I'd think the thickness of the flywheel would be the same as the OE/GM pieces when compared. Both would share the same/similar balance out of the box and the same ring gear.
Old Jan 5, 2014 | 09:59 PM
856SPEED's Avatar
856SPEED
The F-body FW has a different thickness (than the Y-body Corvette) FW; you need to shave roughly .090" from it.......the parts do not interchange w/o machining.........TRUST ME.....
Old Jan 5, 2014 | 10:52 PM
david frederick
That must be, 1lb. weight difference = .090" thank you!
To fidanza flywheel
