Switching to a single plane intake!
Started polishing the elbow
Fabricating a throttle wire bracket
Will go to the US tomorrow and pick up alot of the missing parts for the build so hopefully I will make some real progress soon
http://www.ebay.com/itm/World-Products-061040FI-SBC-305-350-Chevy-Motown-EFI-Aluminum-Intake-Manifold-/161246853903?pt=Motors_Car_Truck_Parts_Accessories&hash=item258b0fbb0f
The bad news is that it seems like the bend hits the hood at the engine compartment light-prob need to make some cuts to the inner reinforcement of the hood to clear the pipe.
A shot from the front shows the brass water injection nozzle holder
The new throttle wire bracket-had to make it from scratch. Its bolted to a welded on piece of aluminum.
Has started to grind on the intake manifold but still some hours of work to go before anything to show.
Just in case I got myself a Motown/Proram intake since it was a sale going on.
Also grinded some in the plenum. Focused the grinding on the shorter runners that were about 20% less in CSA than the longer ones. Most material was removed in the first 1.5 inch on the roof.
The longer runner are just cleaned up (removed casting flash).
This pic was taken when I just have started to grind on the inner runners. Its pretty easy to see the difference in runner height.
When using steel braided PTFE hose its important the hose is grounded to avoid risk for static discharges. Hopefully they are grounded via the couplings but if not I might have to use ground wires.
Its has been very time consuming to find all the coupling, fittings and hoses required but I´m getting alot closer now.
The SMC is now surpassed by a new generation (SM3/SM4) but still works very good; 8 ch sequential injection and very easy to get running.
Its not a plugnPlay installation and it took some time to get it running. Its combined with an Innovative LC1 WB and I´m also running a J&S Safeguard knock control and the OEM EFI in parallell (controlling fans, idle motor etc) -alot of wiring and sensors...
there doesnt seem to very much information on the website, but a google search shows the systems being quite expensive, even second hand ?
When I upgrade my computer Im leaning towards the dynamic efi ebl .
-the elbow slightly touches the hood on three places. Probably sufficient with some light grinding on the elbow to clear. The second issue is more tricky:
After driving about 20 minutes, the engine leans out to the extreme, AFR 18-20-almost like a diesel...
Until this happens, the car is running fine with normal AFR.This is not a WOT thing but happens at idle and cruising. I have checked fuel pressure with and without the vacuum hose attached and the pressure is rock steady at around 40psi. No excessive coolant nor intake air temperature either.
After waiting about 20 minutes, the symptons go away until the car heats up again.
Measured temperature on fuel hoses, rails and regulator and it varies between 120 and 140F. Does not look very extreme to me.
im alwYs running with the fuel cap slightly open since I have deleted the coal canister hence no pressure in the tank.
Im running an in-tank walbro 340 and and inline smaller walbro (dont recall the exact name but the setup was designed and supplied by Greg at Blowerworks).
Was a year or maybe two since I replaced the fuel filter but since the car is running perfect around 20 minutes I cannot see the filter to be the issue.
The engine is in"open loop" so the lambda sensor only measure the oxygen and has no influence on the air/fuel ratio.
Could it be faulty injectors??
