Switching to a single plane intake!
Old Jun 15, 2014 | 06:06 AM
  #61
blackozvet's Avatar
blackozvet
have you checked condition of o2 sensor ?
it will have those symptoms as the computer disregards o2 readings and uses a set fuelling graph under WOT .
although some aftermarket computers can tune at WOT as long as they have wideband o2, does your autronic do this ?
Old Jun 15, 2014 | 08:35 AM
  #62
bogor's Avatar
bogor
One minute the car is running "perfect" at afr 13-14 and suddenly jumps to afr18-20 and starts to stutter. The o2sensor is only reading the oxygen in the exhaust so it cannot cause this (the ECU must be running in close loop to influence afr and its not).
Ignition problems that create misfire shows up as lean when looking at a wideband, will prob look into this as a first step. Maybe the old msd6 box or coil is the root cause?
Old Jun 16, 2014 | 01:46 AM
  #63
blackozvet's Avatar
blackozvet
your ecm operates in open loop mode all the time ?
what is the specific temp that it starts leaning out ? if its temperature related could it be a vacuum leak ? or is that specific temp affecting the msd or wiring ?
Old Jul 1, 2014 | 04:29 PM
  #64
bogor's Avatar
bogor
Well, still misfire
I have now
-changed MSD box
-changed ignition coil
-changed distributor cap
-changed spark plugs
-changed fuel filter
-searched for vacuum leaks "everywhere"
-increased fuel pressure from 40 to 55 psi (to reduce risk for vapor lock)
-added alot of heat protection to the fuel lines
-checked all spark wires for damage
-tested numerous tunes
-checked PCV valve and brake booster
Running out of ideas. Been fighting this for almost three weeks now and I wants to use the car before summer ends.
Maybe switch back to the old superram intake ?
Old Jul 1, 2014 | 06:34 PM
  #65
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Is the misfire on one cylinder or bank?
Old Jul 2, 2014 | 12:09 AM
  #66
blackozvet's Avatar
blackozvet
I will suggest it again (seeing as you have tried just about everything else), have you checked the o2 sensor is operating properly ?
Does your setup use an intercooler ? Could it be a temperature thing related to that, i.e. intake air being too hot ?
Old Jul 2, 2014 | 01:09 AM
  #67
bogor's Avatar
bogor
ECU is running in open loop mode all the time so o2sensor is not affecting things.
Meth inj- no intercooler. Intake air temp is normal when it happens. Also tried cooling spray on the IAT sensor.
Misfire on bank or cylinder: dont know, how do I go about finding this out?
The old sparkplugs all look the same.
Old Jul 2, 2014 | 10:58 AM
  #68
blackozvet's Avatar
blackozvet
could be a fuel problem, if its going lean then it must not be getting fuel,
are you running a knock sensor ? if so the leaning out must be activating the knock sensor and causing the misfire (it will cause the ecm to "kill" the engine),
maybe the knock sensor is too sensitive ?
maybe your fuel setup is sensitive to fuel load in the tank ? How much fuel was in the tank when the symptons happened ?
Old Jul 2, 2014 | 01:53 PM
  #69
bogor's Avatar
bogor
A misfire will be displayed as a lean condition so I think its still up in the air if its ignition or fuel related.
Im running a standalone knocksensor (http://www.jandssafeguard.com/8ChInt...terceptor.html) and if it command retard (ignition only) it is displayed -however no sign of knock retard.
Old Jul 2, 2014 | 06:45 PM
  #70
BrianCunningham
To find a misfire you need to pull the injector connector one at a time and see which one doesn't make it worse
could be the meth injection not getting distributed correctly
Old Jul 2, 2014 | 11:03 PM
  #71
FrankieD's Avatar
FrankieD
This is my analysis and recommendations and the reasons for.
You are running in open loop and using a Wideband O2 in the exhaust just to monitor AFR so this has no relevance to symptoms. You have already checked and or replaced anything to do with ignition such as plugs, wires, distributor and coil. If it was caused by an ignition misfire this would cause raw fuel to be dumped into the exhaust which will definitely cause backfire or popping in the exhaust – which you do not mention of having.
I would recommend that you concentrate your efforts on a faulty injector, injector connector or wiring, or possibly an intermittent injector driver when it gets hot. A misfiring injector will cause your wideband O2 to read very lean.
You can try to run the car until the symptom happens then pull over and with an Ohmmeter measure each injector’s resistance value to see if anything seems abnormal on any one of them.
Hope this gives you some direction to troubleshoot.
Old Jul 3, 2014 | 06:34 AM
  #72
blackozvet's Avatar
blackozvet
you keep surprising me with the stuff you've got running that engine !
Old Jul 3, 2014 | 06:48 AM
  #73
bogor's Avatar
bogor
Sorry, should have mentioned this from the beginning but after I installed an item I tend to forget about it-must be an age thing
Old Jul 3, 2014 | 07:28 AM
  #74
blackozvet's Avatar
blackozvet
maybe its a male version of childbirth, we are able to forget the pain of giving birth to a project and move on with the next one
Old Jul 3, 2014 | 08:20 AM
  #75
bogor's Avatar
bogor
Indeed
Old Jul 4, 2014 | 08:02 AM
  #76
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
I have been following this problem forever and when Bogor finally figures it out I am going to cheer ! What perseverance ! LOL We will all learn from his pain !!!!!!!! greg
Old Jul 4, 2014 | 03:36 PM
  #77
bogor's Avatar
bogor
Without your support I would probably have ended up with a Volvo instead...
Im currently adjusting valve lash and looking into the wiring to the injectors.
Maybe it is an internal problem with the ECU (despite lack of error codes) after all...?
To Switching to a single plane intake!
Old Jul 4, 2014 | 11:28 PM
  #78
blackozvet's Avatar
blackozvet
keep at it bogor, you will find it eventually Im sure
is there any chance that some grit has found its way into the fuel system during the build and found its way into some injectors ?
do you have another set to try, or can you get that set cleaned ?
a bad injector clip or wiring could do it, I know gerard always talks about bad injector wiring that took him over a year to find, and he nearly sold the car cheap he got so sick of chasing the problem.
do you have another ecm to swap in and see what happens ? I had issues with my timing recently, it was going all over the place and pinging (i thought at first my 11:1 compression was too much), no fault codes came up, someone in the club gave my another ecm, I put my chip in, and now it runs like a champ, you just never know with them sometimes !
Old Jul 13, 2014 | 02:24 PM
  #79
bogor's Avatar
bogor
I guess it is possible for some contaminats in the system. I checked the cost for cleaning and flowing the injectors and it was quite steep so I would like to look into some other things first.
I measured resistance between the big ECU connector and the injector clip and resistance was between 0,3 and 0,4 Ohms for all eight clips. I visually inspected the wires and they looked ok.
A good idea to try another ecu box, unfortunately dont know about anyone usingthis particular one but I will have this in mind.
I have another theory about a failing component I will check when Im back frpm a vacation trip next week.
Old Jul 14, 2014 | 06:41 AM
  #80
blackozvet's Avatar
blackozvet
it can be hard to find some things sometimes,
I had a problem where my engine would run rough when it was warm, after checking so many things couldnt find it, I used tunerpro and the only thing that showed up was "low coolant" and I thought that was because i had only just started it and running it in the garage, i did a check after driving it on the road, it showed "low coolant" again,
I checked the sensor and connector clip with the voltmeter and they tested ok,
I replaced the sensor (at $60) no difference, it was only when i was putting the connector clip back on i noticed the connector was broken on the underside and as i pushed it on the pins were pushing back and not going into the sensor, put a new connector on ($6) and problem fixed,
must have taken 2 months to find that one !
