92 corvette
Old Jan 8, 2014 | 09:59 PM
2redvetteguy's Avatar
2redvetteguy
1st Gear
Default 92 corvette
hi,
92 corvette
11" clutch bellhousing
should work, I want to use my hydraulic throwout bearing
will this work
thanks
2redvettesguy
Old Jan 9, 2014 | 07:30 PM
DUB's Avatar
DUB
It all depends on the clutch you pan on using. the factory 6 speed clutches are a pull type....using slave cylinder that pulls the throw-out bearing.
So...it all depends....because this hydraulic throw-out bearing will not work with a stock clutch...or at least I have never seen it work....because hydraulic throw-out bearings (that I have seen) are pushing out...and not pulling.
But then again...I could be wrong.
DUB
