towing with an '86
I have mounted a complete '86 Corvette rear with stock spring under my '57 Suburban, using a Flat Out Engineering kit. Works great, comfortable even with the stock Corvette spring, as long as the truck is empty!!!
According to my info, the weight on the rear of my Suburban is about 300lbs heavier than on the rear of an '86 Corvette, not that much, really.
Anyway, I sometimes tow a 4000lbs camping trailer with my truck and I have to tighten my weight distribution hitch like crazy to do it. I have recently towed 5000 miles in a month like that, so it works, but I would like to "help" my rear suspension a bit!
I was not too lucky with air shocks (leaks) and I fear the bigger effort on upper shock mounts; coil-over do not give much easy adjustability; I could not find an airbag kit for a Corvette rear; I fear that a stronger transverse (steel) spring would make the ride too stiff, too "truck-like".
So, what are you guys' suggestions? Any thoughts?
In particular, can I use airbags between the stock spring and the diff mounting-wings, or is this too much for the plastic spring?
And do not tell me to stop towing with a Corvette rear, I love my truck that way, I just need to fine-tune it!
Thanks!
Contact Chip Foose and ask him....he went to a design school.
...OR...
Why don't you contact a professor at a University or school that deals in automotive design. Maybe he/she can make this "issue" you have be a project for his/her students....and they can learn and get graded on it...or realize it is something that is not done for reasons that may not be so obvious. You never know. Heck it may work. This way you will actually know what it would take to make a rear end for a sports car be used for a truck that hauls a heavy payload.
And for what it is worth...I seriously doubt anyone is going to respond to this post due to what you want an answer to...heck...I may be wrong...but....mainly because it is quite contradictory....much like hiking boots on a ballerina.
DUB
Had a 68 burb , never should have sold it .Did lots of towing with it .
Your asking allot from that glass spring .
Moving the batwing and the spring to a different vehicle such as your truck doesn't really change the C4 cargo weight maximum. It's not the truck, it's the suspension!
You also have to consider the spring itself. Is it a base spring or a Z51 spring? The rates are different. What about the C4 sway bars? Did you install them? They are part of the suspension design.
You mentioned that you tow 4000 lbs. Even with a WD hitch, there is still a good amount of tongue weight. That weight is part of the total weight on the C4 spring. I'll bet that you are waay over the limit for that rear suspension setup.
You say "don't tell me to stop towing.." Well, I think you are way beyond the design limits for what you have and if something breaks, you will be in real trouble. And remember there are other cars on the road. So I do suggest that you find a suitable tow vehicle and one that is set up properly for towing.
My main question is how to have a truck that is comfortablke empty and also able to carry the tongue weight. I do not believe coil-overs would give me that flexibility: with coil-overs, you choose the spring rate and you are stuck with it, I do not want to have to crawl under the truck to adjust the springs each time I tow! An automatic load leveller system would be the best!
Air shocks were (and still are) available for C3 Corvettes, but they are too short for my set-up (I have tried)...
I have not been able to find an airbag kit for a Corvette, but I wonder if, with a slightly stiffer steel spring, I could use an airbag between the spring and the differential-mounting wing?...
And once I sort out the suspension, this truck will be a great tow vehicle, totally suitable for the job! And looking good doing it too! No need for a 9" either. All I need is to put a bit of thinking into it, and figure out what will work...
By the way, what is the rating of the stock, base spring for an '86 Corvette? That will give me a place to start to have a custom spring made.
That could work, as the kit I have used for mounting the Corvette rear came with new, strong upper and lower shock mounts...
I was recommending coil overs since you could choose the perfect spring rate and set the ride height.
Mike
Mike
first I used C3 Corvette air shocks, which were too short for my set-up, then I used Ford Aerostar shocks (picked according to length and vehicle weight), but they really did not help much, they would barely raise the empty truck by an inch, so... And even installed by a pro (after I gave up!), I still had leaks issues, I had to refill them every other day... Not good!
I talked with Gary about a week ago and he mentioned they have made then to 1000lb.
I seriously doubt that the photo that was posted of a Corvette towing some stuff was any where near what you are towing. You are pulling a trailer that is more than the entire curb weight of a 1986 Corvette. You are putting a lot of trust in the ring and pinions ans shafts.
I would seriously look into talking with design engineers on this....but...you are going to do what you want. The only thing I hope is that when something goes really BAD...and it will...just give it time...no one is around so you don't hurt innocent people. You can be opening yourself up for some serious liability. Just because you can customize something...does not actually make it SAFE.
DUB
