N2O routing?
Old Jul 12, 2002 | 03:00 AM
ZAD54's Avatar
ZAD54
Default N2O routing?
I am interested in installing a NOS kit on my '88 and was just wondering how you route the n2o line out of the rear of the car. Do you have to drill a hole to feed the line out or is there a hole available that can be used? :confused:
Old Jul 12, 2002 | 02:03 PM
YellowFvr's Avatar
YellowFvr
Default Re: N2O routing? (ZAD54)
I'm wondering the exact same thing! How to route the nitrous hose from the bottle in the car, through to the engine bay? I allready have my kit, too.
Old Jul 12, 2002 | 03:02 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have done it two ways. One install I routed the nitrous feed line through the firewall at the same point I routed the electrical through. The latest install I routed the lines on the underside of the car and drilled a hole in the rear floorboard and sealed it with RTV. Either way you will just about have to drill a hole, just depends on where you want it to be. Both can be hidden if you remove the system latter on.
To N2O routing?
