Dead/Bad Battery?
Old Jul 12, 2002 | 11:25 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Dead/Bad Battery?
Yesterday i was cleaning out my car, and accidently hit the dimming switch up too much, turning on the interior lights. I didn't relise this untill i tried to start the car hours later. I used a charger(not another car), and it almost started right up with no problem. I drove it around, no problem getting 14.5 volts on the DIC.
This morning it wouldn't start again... The lights all came on, but it just barely wound't turn over. Its out charging again. There wasn't anything on in the car the whole night.
Is the battery bad now?
Old Jul 12, 2002 | 11:37 AM
STL94LT1's Avatar
STL94LT1
Default Re: Dead/Bad Battery? (Mervz)
Most of the time when a weak battery is ran down, they will never reach full charge again. It probably wouldn't hurt to replace the battery, it beats getting stranded.
Old Jul 12, 2002 | 12:10 PM
pzoom's Avatar
pzoom
You might not have fully charged the battery (you didn't say how long of a drive, highway? A/C on? ). How old is the battery? I would trickle charge all night to make sure.
Leaving the lights on once won't ruin a battery unless it was weak in the first place.
I have re-vived batteries by trickle charging every night, drive during the day. Just depends on the age and condition of the internal plates (sulfation).
Old Jul 12, 2002 | 01:16 PM
jfb's Avatar
jfb
The only bad thing that happens with car batteries when they are deep discharged and then charged up is a slight loss in amp hour capacity. Driving your car for a half hour will not charge the battery all the way up. You need to leave the battery charger on the battery for several days and if you drive it , charge it overnight for several days. It sounds to me that you merely have a discharged battery. I would also remove the cables and clean them and the battery posts.
Old Jul 12, 2002 | 02:04 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
well, i trickle charged it for a few hours this morning, and then drove it about 15 miles. It seems fine now, but i will see later... :)
Old Jul 12, 2002 | 02:08 PM
scorp508's Avatar
scorp508
Put a real battery charger on it. If you let your alternator charge it for you, you will soon be Brian Cunningham. :p: :D
Old Jul 12, 2002 | 02:53 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: (scorp508)
I did, its a nice big one... :yesnod:
Not a small trickle charger..
To Dead/Bad Battery?
