Reluctant "Performance Chip" Question...
Old Jan 22, 2014 | 11:58 PM
DrDyno's Avatar
DrDyno
Default Reluctant "Performance Chip" Question...
Hi All,
I'm new to the C4 experience. I've had many C1's, C2's and C3's back in the day and, after 30 years Corvette-less, just purchased a '96 LT1.
In my day, a Dwell/Tach, Timing Light, screwdriver and offset 9/16 wrench were all you needed to optimize your small block's performance. Now, I can't even find the distributor! (yes, I know, "Optispark," behind the water pump.)
So, with all the advertisements for "Performance Chips" and "Throttle Control" IC's, do any of them actually improve power/performance?
Oh and... can you time an LT1 with a timing light?
Sorry for my ignorance!
Old Jan 23, 2014 | 12:13 AM
DanielRicany's Avatar
DanielRicany
First, the LT1 timing is controlled in the tune, so no you can't time it with a timing light. And secondly, I wouldn't buy any performance chips because I think they are a waste of money. If you want a tune, get it done specifically for your car from a reputable tuner.
I think people have been saying chips like Hypertech only lower your fan speed to keep the engine running cooler.
Old Jan 23, 2014 | 01:05 AM
ANTI VENOM's Avatar
ANTI VENOM
Congrats on the new car. Good choice. If the car is stock, don't waste your money. Just my .02
Old Feb 1, 2014 | 01:44 AM
npd4432's Avatar
npd4432
Your car being a 96 is an obd 2 car. There are no "chips" available. The car must be tuned through flashing the PCM. Tunercat and lt1 edit are programs you can use to optimize and customize performance.
Old Feb 1, 2014 | 06:59 AM
WW7's Avatar
WW7
Don't mess with anything ( as far as tuning goes) unless you make a major engine parts modification, then you may need a retune ...The factory tune is fine for a stock car.......WW
Old Feb 1, 2014 | 11:47 AM
DrDyno's Avatar
DrDyno
Thanks, Guys... I have no complaints about my car's performance, stock. Just wondering if there was some little, inexpensive tweak available. And, as always, don't need to fix what isn't broke.
Again, thanks for your responses!
To Reluctant "Performance Chip" Question...
