what injector size
Old Jan 26, 2014 | 12:59 PM
GS977's Avatar
GS977
Default what injector size
what size injectors do I need for a 384ci lt4 with @450rwhp.
42psi ? I have ford red tops now that I read were good to @ 400 hp.
the red tops are 30psi correct?
Old Jan 26, 2014 | 01:14 PM
armysnipe's Avatar
armysnipe
There's an injector size calculator at fuel injection connection.com that may help you decide.
Old Jan 26, 2014 | 02:37 PM
MrWillys's Avatar
MrWillys
A 36 lb injector installed at 46 psi will feed 450 hp at 80 % duty cycle assuming a brake specific of 52.
Old Jan 26, 2014 | 04:19 PM
_ski_dwn_it's Avatar
_ski_dwn_it
A 24lb injector is more than enough. Have a buddy with 383 in the 10s with them and I have run my 434 with 24lb injectors into the bottom tens for years. Run 48psi.
Old Jan 26, 2014 | 05:09 PM
leesvet's Avatar
leesvet
I'd think that 24lb/hr would be good, but if you want to KNOW.....call Jon.
he knows more and can provide more info on injectors off top of his head than most can come up with from a book..or a degree.
Very smart guy.
See his videos on you-tube under FIC or simply fuel injector.
To what injector size
