Compreasion normal range
Old Jan 27, 2014 | 10:12 AM
hitmanpty's Avatar
hitmanpty
Default Compreasion normal range
Hi every one.
If I do a compression test on my cylinders. 1986 iron head vette.
what is consider a normal reading psi.. according to factory specs
Old Jan 27, 2014 | 12:20 PM
powerpigz-51's Avatar
powerpigz-51
Anything above 90 should run, but you are looking mostly for differences between cylinders. I would mostly think readings between 125-175 is average for a well used motor.
Old Jan 28, 2014 | 12:42 AM
Cliff Harris's Avatar
Cliff Harris
These are the readings I got on my car at 61,220 miles:
1 - 185 ... 2 - 140
3 - 190 ... 4 - 160
5 - 190 ... 6 - 170
7 - 185 ... 8 - 175
This is what I got at 90,317 miles (I forgot to block open the throttle):
1 - 160 ... 2 - 147
3 - 160 ... 4 - 155
5 - 170 ... 6 - 140
7 - 165 ... 8 - 155
To Compreasion normal range
