1987 MAF Sensor
Old Jan 31, 2014 | 12:13 PM
kmclaughlin's Avatar
kmclaughlin
5th Gear
Default 1987 MAF Sensor
Hello:
Does anyone have a link or pic where exactly the MAF sensor is located on my 1987 C4? Been told to check for cleaning first...thank you!
Old Jan 31, 2014 | 12:28 PM
WW7's Avatar
WW7
Originally Posted by kmclaughlin
Hello:
It's located between your air filter holder and the Throttle body, it's connected to a plastic rippled tube....Can't miss it, it's a round Black plastic tube about 6 inchs long with a clamp at both ends.., it has a plug going to the bottom of it..Sorry, I don't have a picture handy...Let me just say ( be very careful with this piece, it has a very thin wire inside and if you break this wire your screwed) ....Make sure if you clean it to use (Mass Air Flow Sensor Cleaner) you can't use anything else.......WW
PS...Here you go, I did find a picture for you.....WW
http://forums.corvetteforum.com/1585191890-post1.html
Old Jan 31, 2014 | 01:05 PM
vader86's Avatar
vader86
If you are getting MAF codes, replace the two relays behind the battery first. If you do end up needing a MAF, you'll need to replace em anyway. Together they are like $20.
There is a test procedure available to determine the problem if you have the manual. If not, we can pull up the PDF of the procedure depending on the code you have.
Old Jan 31, 2014 | 02:00 PM
kmclaughlin
5th Gear
Originally Posted by WW7
It's located between your air filter holder and the Throttle body, it's connected to a plastic rippled tube....Can't miss it, it's a round Black plastic tube about 6 inchs long with a clamp at both ends.., it has a plug going to the bottom of it..Sorry, I don't have a picture handy...Let me just say ( be very careful with this piece, it has a very thin wire inside and if you break this wire your screwed) ....Make sure when you clean it to use (Mass Air Flow Sensor Cleaner) you can't use anything else.......WW
You ROCK! Thank you!
Old Jan 31, 2014 | 03:40 PM
tunedport85inject's Avatar
tunedport85inject
i'm not a fan of cleaning this unit,it's very sensitive the thin wire and the sensing tab is coated with a thin film ,use the wrong product to clean it and you'r screwed:600 $ for a new unit 300 $ for a remanufactured...
Old Jan 31, 2014 | 07:01 PM
Black LS2's Avatar
Black LS2
Leave the MAF alone, and replace the relays behind the battery. On an 87 they are 14089936.... some if the best money you can spend on an early C4.
One, the burn off relay, even cleans the MAF by heating up the wire to burn off contaminants.
Old Jan 31, 2014 | 07:07 PM
kmclaughlin
5th Gear
Thank you!
To 1987 MAF Sensor
