Realistic hp gains
Old Feb 3, 2014 | 02:29 PM
sansonic's Avatar
sansonic
Default Realistic hp gains
Hey guys im in the middle of an engine swap in my 86 and im wondering how much power i might gain from this stuff. So basically i started with a stock 86 so 230hp and 230 tq i guess. Im putting an 87 motor in that has the aluminum heads. So right of that bat i gain 10 hp and 15 tq.
Now im putting obx headers on the new engine along with throwing out the old cats and running flow master mufflers. I have a k&n air filter 180 thermo and im going to get it tuned at pcm for less. The car will have pretty much new everything fuel injectors egr all the basic stuff it needs to run good. Should i get a hotter coil for it and gap the plugs more? Or is that a waste of time? Its got 3.07 rear gears on it. Besides what i said above im not willing to change the heads or intake or came right now. I really just want to drive it
But while im here i might as well do these little things. What do you guys think my gains will be like?
Old Feb 3, 2014 | 02:36 PM
TA's Avatar
TA
Your old engine stock was probably putting down 200 or so HP at the rear wheels. With the minor mods you've mentioned I'm guessing you'd be up to 225 HP at the wheels give or take. If you want a more realistic number you'd have to dyno before/after or take it to the track before/after. Either way, you're not looking at a significant increase without more mods (intake, heads, cam).
Old Feb 3, 2014 | 02:38 PM
DanielRicany's Avatar
DanielRicany
I think it might make around 270 HP.
Old Feb 3, 2014 | 02:43 PM
sansonic's Avatar
sansonic
That old motor could barely spin the tires from a dead stop. I think it was on its last legs. I really just hope if i punch it without the brake on it will roast them. Other than that it was fast enough for me but it couldnt hurt to be a little faster.
Old Feb 3, 2014 | 02:56 PM
John A. Marker's Avatar
John A. Marker
The HP of 230 for the 86 is measured at the engine not the rear wheels.
The 87 was stock with 240 HP at the engine and 343 pounds of torque. You will probably pick up 10-15 HP with the headers. Filter and thermostat will give you nothing. Tune might pick up a couple of HP but not much. Hotter coil will give you nothing...same with the gap on the plugs. The HEI should be able to jump a gap to about .45 if you really want, but will not yield anything to make the engine run better or add HP. I would keep the gap at .35.
You would pick up some HP with new heads and really make things happen with heads, cam and intake. Add 1.6 roller rockers to the stock engine and pick up another 3-5 HP.
All your changes on the conservative side will give you about 250 at the crank or about 210 at the rear wheels. You loose about 15-20% from the crank to the rear end.
Old Feb 3, 2014 | 02:59 PM
sansonic's Avatar
sansonic
Thank you. Eventually i will do the heads cam and intake i just do not have the funds right now. I will be set up for it when i do though.
Old Feb 3, 2014 | 03:00 PM
vader86's Avatar
vader86
I figure 250-260 crank hp.
Old Feb 3, 2014 | 04:29 PM
powerpigz-51's Avatar
powerpigz-51
Old Feb 4, 2014 | 12:58 PM
sansonic's Avatar
sansonic
Thanks for all the input one last question. Do you think i will be able to feel the difference? Like will the car feel like its been woken up? Right now im stuck driving a little saturn with about 100hp and 100tq so i know it will feel waay faster than that. Im just really exicted to be driving my vette again i cant wait.
Old Feb 4, 2014 | 01:31 PM
John A. Marker
Add the headers and the roller rockers and there will be a seat of the pants difference. When I first started to mod the 85, one of the first things I did was add 1.5 & 1.6 RR's. You could feel the difference. This won't be throw you back against the seat....but you will notice.
Old Feb 4, 2014 | 03:41 PM
vader86's Avatar
vader86
Yes you will, especially the headers.
Old Feb 4, 2014 | 05:39 PM
383vett's Avatar
383vett
It's amazing when you start throwing money and parts at one of these cars, the car feels much faster even though it may or may not be. After every change, you will get an "aww, that's faster" feeling.
Old Feb 7, 2014 | 10:17 AM
sansonic's Avatar
sansonic
Would there be any power gains to putting an adjustable fuel pressure regulator? I actually have an upgraded fuel pump in the car (got a good deal on it) its a walbro 255l/hr fuel pump i think the part number is gss204m. I know its a overkill for this car but if adding a little fuel pressure could help with the headers and the tune id be down for it.
Old Feb 7, 2014 | 10:45 AM
John A. Marker
No noticeable gains with a adjustable fuel pressure regulator. Stock fuel pump is good for up to about 400 HP and your a LONG way from there.
Go to the above post by Vader86 and click on his name...then down to his home page and visit. He has a listing of things that help and those that do not.
Cut out the cover over the air filter. You can play with the distributor base setting to see what your car likes. Standard is 6 degrees, but my 85 liked 10 better. You can also adjust the TPS to .60 and will give you a little more quick pickup. Cut back the spark plugs and that will add a whole 1/4 HP...but they all add up. Take the money you would have spent on the fuel pump and buy the March 3 piece underdrive pulleys.
If you get adventurous and are willing to try this yourself, gasket match the runners to the intake, match the runners to the plenum and port the plenum. Easy to do with a die grinder.
Old Feb 7, 2014 | 12:45 PM
vader86's Avatar
vader86
No, its for tuning purposes to optimize, but you're not going to unlock a bunch of power from being able to raise FP a couple pounds.
The Walbro is what I have, its more than plenty for you.
Old Feb 7, 2014 | 03:26 PM
sansonic's Avatar
sansonic
Fuel pump is already in the car. Before i pulled the motor the fuel pump went out so its there to stay for a while. Whats the deal with the march 3 piece underdrive pulley? What kind of gains are there?
Old Feb 7, 2014 | 03:30 PM
John A. Marker
Reduces the parasitic drain from the accessories by reducing the pulley size. The pulley for the alternator is a little larger so the alternator is still able to put out the amps at idle.
This allows the engine to spin up a little faster into your HP/Torque range.
From Vader86's site..... "Personally I dont like this mod, because I dont like the idea of my Alternator spinning any slower than it already does, especially since the C4 eats alternators. However, track tests show that you could get .1 in the 1/4mi just from this, which equates to about 10hp."
To Realistic hp gains
Old Feb 7, 2014 | 05:01 PM
Calderone's Avatar
Calderone
Heads & Cam while your engine it's out please !!!
Old Feb 7, 2014 | 06:18 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Look.
If your looking for extra power put a cam in that motor!
The cost is not prohibitive like heads abut you'll add 40-50 smiles per mile easy.
Then pickup the heads later on.
All that other junk your looking at is worthless... in comparison
Old Feb 7, 2014 | 06:51 PM
five7kid's Avatar
five7kid
Loud exhaust gives the best SOTP power improvement.
The car isn't any faster, but it sure feels like it is.
