Another Dirty Radaitor
Old Jul 13, 2002 | 04:16 PM
Rich_01659's Avatar
Rich_01659
Default Another Dirty Radaitor
if your reading this chances are you have either just cleaned yours or you feel quilty because you have not cleaned yours yet. my 94 was running too hot and with the heat wave in CA i needed to do something. I removed and cleaned the radiator. I looked inside the shroud before i removed it and it LOOKED clean. Well it was dirty and so was the condensor. after cleaning both and having already installed the 160 stat and fan switch ..... it was 116 degrees the next day and with ac on full blast and driving normal some hwy some city the highest engine temp i got was 212 degrees. So go clean those radiators. First timer takes about 2.5 hours.
