Engine pulling time!
Old Feb 6, 2014 | 02:37 PM
ishootstuff's Avatar
ishootstuff
Default Engine pulling time!
I bought a rat nest in an 85 as I stated in my intro thread.
Finally got around to pulling the engine. I had to pull the heads in the car because there was still too much cactus and debris which prevented access to the transmission to engine bolts. It's just about ready to come out.
Looks like she has a broken crankshaft. I can move the front 6 pistons a little in their cylinders before the rear two move.
Old Feb 6, 2014 | 04:58 PM
MrWillys's Avatar
MrWillys
That's funny stuff. I'd be curious to see if the crank is bad. Don't hear about them failing too often. Keep us updated.
Old Feb 6, 2014 | 05:30 PM
BOOT77's Avatar
BOOT77
Read somewhere 85 was a steel crank? Prob a rod.
Old Feb 6, 2014 | 05:46 PM
ishootstuff
Sure enough, broken crankshaft. This is only the second one I have ever seen. The first was in my 86 Cherokee which had the 2.8 Chevy 60 degree V6.
I think this engine has been rebuilt before - unless TRW pistons are stock.
Old Feb 6, 2014 | 06:20 PM
xrav22's Avatar
xrav22
TRW pistons were stock in 85
Old Feb 6, 2014 | 07:29 PM
MrWillys's Avatar
MrWillys
What would cause this? Do you think 7 or 8 hydrolocked?
Old Feb 7, 2014 | 09:40 AM
ishootstuff
Wow. Cool.
I don't see any evidence of water ingestion or fuel injectors stuck on. I'd like to know the root cause, but I don't think I ever will.
Old Feb 7, 2014 | 04:02 PM
ishootstuff
More pics...
Old Feb 7, 2014 | 08:59 PM
ishootstuff
Well... Looks like it's time for a crate engine. I don't like the wear on this main journal. The main cap is worse. Jegs has a 260 horse free shipping no tax longblock deal for $1530.
Anyone see any issues using THIS ENGINE?
Old Feb 7, 2014 | 10:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thrust bearing all copper wow. What did the harmonic balancer look like? Guessing a GM crate would be somewhat reliable.
Old Feb 8, 2014 | 01:54 AM
blackozvet's Avatar
blackozvet
Im thinking the rats probably chewed thru that crank !!
that engine is junk, easier and cheaper to buy a built motor !
Old Feb 8, 2014 | 02:25 AM
illenema's Avatar
illenema
Dam. Sounds like fun
Old Feb 8, 2014 | 07:31 AM
ishootstuff
Balancer isn't separated, and was still on the crank plenty tight. No significant oil seal wear groove. Seems good.
Old Feb 8, 2014 | 09:33 AM
WW7's Avatar
WW7
JB Weld??.......WW
Old Feb 8, 2014 | 09:59 AM
ishootstuff
Originally Posted by WW7
JB Weld??.......WW
That's what I did to my old 2.8 V6 Jeep when I was broke. It worked for as long as I needed it to work.
Old Feb 8, 2014 | 10:44 AM
Rob31's Avatar
Rob31
Ive never seen a stock piston like that .
Old Feb 8, 2014 | 12:07 PM
MrWillys's Avatar
MrWillys
If all you can afford is the base GM Target engine it will operate well. The ZZ4 would be my choice that will work with stock programming. Can be tuned (I hate this word) but will work.
To Engine pulling time!
Old Feb 8, 2014 | 01:31 PM
mtwoolford's Avatar
mtwoolford
Well for beginners, it has a flat tappet cam; and with the removal of zinc and phosphorous from engine oils for emissions reasons, lobe failure is always a concern. There are aftermarket lifters that are designed to provide extra oil to the lifter / cam interface...so that might be an option.
But...why not a 86 or later block with a factory hydraulic roller cam? sure it has a one piece rear seal style crank shaft that will require a newer style flexplate or flywheel, but it also has a better rear seal and better one piece pan gasket.
Old Feb 8, 2014 | 05:02 PM
ghoastrider1's Avatar
ghoastrider1
I believe rollers/one piece rear seal,started in 87, not 86. Alum, heads started mid 86.
Old Feb 8, 2014 | 05:19 PM
WW7's Avatar
WW7
Check out the motors and prices here.......WW
http://paceperformance.com/
How about this motor? 355 cube motor with roller cam, 1 piece rear main , 4 bolt block, internally balanced , plus free shipping, ........................... 30 month / 50,000 mile parts & labor warranty.....................WW
http://paceperformance.com/i-8396343...rear-seal.html
